Thread: Slugged my plaster
    May 2014
    Pflugerville, TX
    148
    Slugged my plaster
    I think I managed to slug my plaster. There's a lighter colored area about where i pour my acid at the bottom of the pool. Problem is I pour in front of a return jet... So how did it slug up and sink?
    Also will my plaster be ok?
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    Aug 2010
    Dallas, TX
    4,052
    Re: Slugged my plaster
    You should slowly pour by a return, then sweep to disperse.
    Can you post pictures?
    May 2014
    Pflugerville, TX
    148
    Quote Originally Posted by RobbieH View Post
    I can try and get a picture, I tried last night but I wasn't having luck due to glare.
