Results 1 to 10 of 10
Thread: Closing Pool up for winter using the BBB method
    rcroller4711's Avatar
    Aug 2011
    Saint Louis, Missouri
    67
    Cool Closing Pool up for winter using the BBB method
    What is the procedure for closing the pool using the BBB method? This is my first year using the BBB method, what a great summer, so I'm new to closing this way. Also since using the BBB method I don't want to clean out my filter's sand. I'd rather reuse it next summer. So..... do I just drain the water out of the filter and store as is then? If not what's your tip? Man, I love this BBB. The cleanest, the sweetest and the easiest cleaning I have ever experienced.
    18' Round AGP, 8,600 gallons, sand filter.
    38,284
    Re: Closing Pool up for winter using the BBB method
    Start with the article in Pool School: http://www.troublefreepool.com/conte...ove-group-pool
    Ask questions if you still have them.
    Aug 2011
    67
    This a article says to wait until the pool water gets down to 60 degrees before closing it. Why?
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by rcroller4711 View Post
    Algae becomes inactive below 60f
    Support the site
    38,284
    I would say less active, not necessarily inactive.
    May 2014
    Franklin, NC
    9,184
    Picky, picky, picky.....
    Support the site
    38,284
    Well it still grows just slower.
    Casey's Avatar
    SW PA
    10,438
    I have closed early and I have closed late. The last 2 years I've closed early and just closed today. I SLAM to 20ppm, drain and cover. If you want to use Polyquat 60, go for it but you don't have to. Just open before May and you're golden. You should have no problems. I never have.
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    Quote Originally Posted by Casey View Post
    Sad to hear that since I'm not far from you. Temps are forecasted for low 70s for the 10 day and 40s at night. I'll give it a couple more weeks. If nothing, I'll take the cover off and wait till the water hits 60.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    Jun 2012
    SW Pennsylvania
    77
    I am closing earlier than the previous 2 years, because I believe without a heater the swimming season is gone and I don't want to be cold doing it. I brushed, vacuumed and covered with winter cover but will continue circulation and water tests until the water drops 10 more degrees. Then I will bring chlorine to shock level and drain hoses and pool water to below skimmer. I didn't want to keep scooping leaves out, it was depressing. The last few days in the pool...that was my entertainment. Scooping with a butterfly net as they fell....Last two years I did everything in the same day after water was below 60...It was not fun...I did not have the deck last year. Thank you all for helping learn this process...
    AG AquaLeader 21x43 Oval 54" deep. Hayward 2speed 2HP pump,Hayward 350,000 BTU NG Heater, Cartridge filter. Since August 2012. TFT 100 test kit
