Results 1 to 10 of 10
Thread: LED Bulb replacement
    Sep 2014
    Loganville, Ga
    6
    I am about to change the burnt out bulb in my pool and wanted to change to an LED. My current bulb is a 120V 500W. While searching a replacement LED, I came across this one....
    http://www.amazon.com/gp/product/B00...YXKHG67ZWETKAR
    Now the price at $88.50 is about half what most of the LED's are. Any use this bulb before? Do you think it is worth the gamble?
    38,539
    Re: LED Bulb replacement
    Welcome to TFP!!!
    I have not noticed them mentioned on the forum before. You might have to be the guinea pig
    Did you consider one of the color changing LED bulbs? I put a ColorSplash 3G in mine ... certainly not as bright as the white, but the kids like it.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Your links' write up mentions a fan for reliability. Cheaply made electrical components sometimes run hot, then boast a fan for "performance". What i would do if you want to get this light would be to run it in a household socket and observe if there is indeed a significant heat output. Keep in mind that when the bulb is in the light fixture, there is no ventilation. I would be willing to bet that the led would fail (if heat were a problem) long before the fixtures own heat cutoff switch was activated.
    Factory Warranty Station for:
    Sep 2014
    Loganville, Ga
    6
    So you think it would be ok to run in a household lamp? LEDs aren't supposed to provide alot of heat so it may be fine.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Welcome to TFP!!!
    Is this just a bulb that replaces the old bulb?
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    38,539
    Quote Originally Posted by boston62 View Post
    Sent from my SCH-I535 using Tapatalk
    Yes. You change the color or light show by toggling the light switch.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Should you buy two if both pool & spa are operated on one circuit?
    Autopilot SWG
    38,539
    The manual indicates that they can be synced together if on the same light switch.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Thanks for the info will search for it...
    Autopilot SWG
    38,539
    You can find info here: http://jandjpoolspa.com
