Results 1 to 19 of 19
Thread: Acid Aeration
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Acid Aeration
    So it seems I need to create a homemade aerator to lower my TA. How do I get the eyeball out of my return to screw homemade contraption in? I'm not mechanically brain equipped so I think I am going to need step by step instructions for this one ...
    Lynzizzle
    IG, 25k gal (est.), concrete free form, Hayward S-244T 300lb sand filter,
    well water, Pump: AO Smith 3/4 hp, VSpd: Unknown, Pool Age: Unknown
    Welcome to our OOL. Notice there's no "P" in it?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Acid Aeration
    Return eyeballs are typically 1.5" MIP threaded. If you want to go the no-fuss route. Check out this on Amazon http://www.amazon.com/Splash-A-Round...ool+return+jet
    I have not tried it, but it looks like it would do the job.
    Otherwise you could have a look at that design and copy with PVC.
    This thread has a simple one that would work too. http://www.troublefreepool.com/threads/7457-My-aerator
    Isolated Spa - 345 Gallons
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Acid Aeration
    There should be two threaded sections on the return. You can see it here http://www.poolpartsonline.com/p-243...ing-parts.aspx
    The outer ring unscrews partially to allow the eyeball to be adjusted or fully to allow you to remove the eyeball. The inner piece is a little more difficult to remove. It has a couple of notches inside it to something to grab it and unscrew it from the return. Sometimes when you remove the outer ring, the whole fitting comes out.
    Here is the commercial tool for removing the inner ring http://www.amazon.com/Hayward-SP1419.../dp/B003VSO1PI
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Re: Acid Aeration
    So that's how you move the eye ball! If I just loosen that fitting and aim the eyes towards the top of the water is that enough aeration to bring my TA down you think? Or does the water need to be catching oxygen and then hitting the water again for it to aerate properly?
    This looks like something I would need. Unless someone told me exact parts to get to make it myself. haha. Thank you, I never knew such things existed!
    Quote Originally Posted by JVTrain View Post
    Lynzizzle
    Jun 2013
    East TN
    309
    Re: Acid Aeration
    The more tiny bubbles the faster it will aerate. You could turn the fitting up where it shoots out of the water but it doesnt work as fast.
    This one is my favorite:
    http://www.troublefreepool.com/threa...l=1#post695298
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Aug 2010
    Dallas, TX
    4,052
    Re: Acid Aeration
    Turn the pump off before you try to move the eyeball. Common issue is that people think they won't move, but the pump is on restricting the ability to move them.
    Jun 2014
    860
    Acid Aeration
    @lynzizzle
    I think your biggest issue is really the high TA of your fill water. In your previous post you measured at TA of 580ppm which is quite high. So every time your fill water hits the pool, you're adding back an enormous amount of alkalinity.
    There are no hard and fast numbers on how acid-aeration affects TA. But in order to do it properly, you're going to need a lot of acid since you'll need to get your pH down to 7.0-7.2 before aeration. It's going to take a lot of patient work to reduce the TA by any significant amount.
    Constructing a water cooler/aerator is a great first step. You might want to consider using a shower hear or fountain to do the aeration as breaking up the water into small droplets and letting it splash down onto the water surface will have the greatest impact on releasing the dissolved CO2 in the water. Just pointing an eyeball return upwards will do very little.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Acid Aeration
    Quote Originally Posted by lynzizzle View Post
    You don't have to use an aerator. It just speeds things up. The PH will usually rise on it's own, albeit slowly, with just normal pool activity.
    I have very high TA fill water and am constantly fighting high TA and high PH but I don't bother with aeration because it is futile. I just keep PH at the lower end of the range and the CSI slightly negative and TA comes down on it's own and settles in a range around 90-100 ppm.
    Mark
    May 2014
    Pflugerville, TX
    148
    Re: Acid Aeration
    Quote Originally Posted by JohnT View Post
    That thing is a joke. I tried to spin one of my fittings out with that (and channel locks on the plastic tool) and all I did was round the plastic tool where it fit in the grooves on the threaded coupler. All of mine are on so tight (from the builder?) that that tool did nothing. I had to have someone come out and basically chizel it out so I could replace the whole eyeball assembly (was a different brand and the eyeball didnt tighten with the coupler that was stuck in the wall.... grr)
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Acid Aeration
    I think using a return aerator is a bothersome way to effect aeration. Especially in colder weather, you'll be having lots of fun reaching into that frigid water.
    My suggestion is to head over to Harbor Freight or a big box home improvement store and spend $45-$60 on an immersible sump pump. You can set it on any steps going into your pool or drop it to the bottom in the shallow end and plug it into a wall socket. It'll move enormous amounts of water and produce plenty of bubbles. The only additional thing you would need would be a few PVC pipe fittings to screw into the pump's output to point the water spray in whatever direction you want. You'll be able to lift it out of the water when your done without getting wet and it's also useful if you have to drain your pool below your pump intake or if your pump dies someday and you need a temporary way to circulate water.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Jun 2014
    860
    Re: Acid Aeration
    Quote Originally Posted by gtemkin View Post
    I always thought it would be quite interesting to hook up a Venturi air line (with an automated shutoff valve) to the main return water line as a way of introducing air bubbles into the return water stream.
    That way you could program in aeration into your pool water.
    Wonder if anyone has any thoughts on the downside if hacking up your PVC at the equipment pad to do something like this?
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Acid Aeration
    Quote Originally Posted by SunnyOptimism View Post
    Interesting idea. The PVC work to accomplish that would be fairly trivial. I'm guessing most TFP adopters don't need aeration frequently, however when you have 500+ TA fill water like the OP, it may be more attractive.
    Jun 2014
    860
    Acid Aeration
    All you'd need to add is one of these and perhaps do it using a bypass loop that can be valved off
    http://m.aliexpress.com/item/2009426691.html
    Oct 2013
    Chapin, SC
    1,141
    Re: Acid Aeration
    Here's a pic of my aerator: https://www.dropbox.com/s/iflrskg5qk...rator.jpg?dl=0
    about 4-5Ft of 1.5 inch pvc, one T, two end caps, Three male threaded adapters one adjustable union ( the most expensive part of mine) because I want to be able to adjust it. And a little pvc cement. The blue arrows point to most of the glued parts. The red arrow are where its only hand tight and thus adjustable. Drill some 1/4" holes in the horizontal part. Screw it into the fitting you removed the eyeball fitting from. Pretty simple if not just a tad overkill using the adjustable union. That red arrow on the left end should be blue. PM me if you have any questions.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Re: Acid Aeration
    What r u people even talking about? I am so lost.
    Lynzizzle
    Feb 2014
    Central Minnesota
    5,080
    Re: Acid Aeration
    The topic has gone well off the deep end with suggestions for introducing aeration. Stick to something basic such a purchased set up like I linked earlier or a basic PVC construction, if you'd like to make your own. That should be plenty to help you address the high TA.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Re: Acid Aeration
    I am ... Put it together last night but didn't glue it as per the directions and it all just fell over so I had to let it dry so I can start over and glue it all together ... P
    Lynzizzle
    Jun 2014
    860
    Acid Aeration
    Side discussion moved to To aerate or not to aerate that is the discussion. Zea3
    Hahahahaha....sorry about that. We definitely derailed your simple question
    I asked the ModSquad to separate all the posts that @mas985 and I were trading back and forth. That'll clean up the timeline a bit.
    As my dad always preached to me as a kid, "keep it simple, stupid!" Words to live by......
    Feb 2014
    Central Minnesota
    5,080
    Re: Acid Aeration
    good start!
