Results 1 to 9 of 9
Thread: Mineral springs bioguard system no display
    I have a mineral springs system which has stopped working...no power at the display, no chlorine in the pool. breaker is ok, cell is new replaced transistor on board last year...any suggestions would be appretiated. Thanks
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Mineral springs bioguard system no display
    Can't Help,you with the SWG problem but you need to get some chlorine in the water fast or you will have a green pool. Plain bleach will,work.
    Support the site
    Yes, Thank you, What I should have said was it is not producing chlorine...I have been adding since I noticed the swg was not working
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by gprising View Post
    that makes me feel better. How old is it? Could it be at the end of the cells life?
    Support the site
    the t cell is new last year. think the system as a whole is about 10 years old
    If you're not getting anything on the display, you could try resetting the display board. Turn off power to the unit and then remove and reinstall the display board.
    If your power light is out, then it might be the thermistor.
    Support the site
    There are no lights on...I replaced the thermistor and there are still no lights on. I will try resetting the display but think I am in fir a new board.
    Check to make sure that you're getting good power to the box.
    Support the site
    Thanks for the help...think I am in for a new unit.
