Thread: Lights out!
    Aug 2013
    Mcallen, TX
    39
    Lights out!
    I noticed today that the lights showing generating and power are off on my swg but it's still reading the salt level. Does anyone know if that swg will turn off if it doesn't need to generate salt, I have it set like at 50% running for like 8 hrs because it's been generating more than enough FC. I checked chlorine today and it's at 6 ppm.
    17k gallon pool, pentair whisperflo pump 1hp, Pentair FNS Plus 36, SWG Hayward Turbo Cell 15 40,000g, blue quartz with pebble finish landings/bench, ultra pure water cleaner.
    Re: Lights out!
    If the switch is on "Auto" and the unit has power, then the power light should be on. Try scrolling through diagnostics and report the readings.
    Support the site
    Jul 2013
    Lelystad, The Netherlands
    60
    Re: Lights out!
    Can you post a picture of te controll unit ?
    Mine has a digital timer display for the percentage of generated. If yours is set to 50% , maybe you just looked at the moment it isn't generating because it allready did a bunch of time of the 50% ?
    40000 liter in ground vinyl pool with SWG : http://www.troublefreepool.com/threa...he-Netherlands
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    chiefwej
