Results 1 to 11 of 11
Thread: Pool Light
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Pool Light
    Is it possible to get rust in the pool light, I am asking because I see a brown spot on the bottom of the light inside. It is the whole bottom of the light, about a half an inch wide. Thanks
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Pool Light
    I took the light out, cleaned it, there was some water in it, put it back, first checking to see if any air bubbles were coming up when I submerged it...
    Autopilot SWG
    Aug 2013
    Oklahoma City, OK
    140
    Re: Pool Light
    Quote Originally Posted by boston62 View Post
    Sent from my SCH-I535 using Tapatalk
    If you see water inside the light the seal and bulb need to be changed. The light is obviously no good.
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Pool Light
    There's no water in it now, it does work, will order a new gasket. Why change the bulb if it still working?
    Autopilot SWG
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Pool Light
    I have a an older SAM color wheel light and after time they leak water from where the electrical cord goes into the housing. I need a new light next year. I had someone try to fix it this year but the ground fault started tripping after a week so I just shut off the breaker for the rest of the summer. They indicated that with my older AquaLink RS8 I would need a new control board if I wanted a LED color light. I probably will just go with a halogen type, I think they are brighter anyways.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Pool Light
    I have the IAqualink also, you need a new board to use a LED light?
    Autopilot SWG
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Pool Light
    My system is about 12 years old and that's what the pool company I use for repairs told me. He said the LED's have a separate circuit to change the colors which the older RS8 boards don't have. I have not researched to verify. If that is the case I won't be paying 500 bucks for a new board and will go with the halagn bulbs.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Pool Light
    Oh OK I installed mine this year.. I see it listed in the menu...
    Autopilot SWG
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Re: Pool Light
    If there's no water in it and the bulb is working, why change anything?
    My experience was pull out the light, replace bulb, use old gasket, it leaked.
    Buy new gasket, still leaked. Retried w/ goop all around gasket, still leaked.
    Trustworthy pool guy tried same and with a second new gasket, still leaked.
    Bought a whole new sealed fixture and had it installed - no leaks.
    If I was as lucky as you are now, I'd leave well enough alone.
    YMMV. Good luck!
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Pool Light
    Yes you are correct, I did remove it to see why there was a brown water mark on the bottom of the lense, when I opened it, some water came out, I took it apart, cleaned everything, reinstalled the gasket, submerged it, and it was water tight...I will keep an eye on it. I did order new gasket & pilot screw just case.
    Autopilot SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: Pool Light
    Does the glass it self have to be in a certain position?
    Autopilot SWG
