Thread: Winterizing in ground pools in Houston,TX. Do Ineed to do anything special?
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    Hello all new pool owner here, getting ready for winter. I was wondering if there was anything special I had to do before winter hits. I live close Houston,Texas so our winters are really mild. We do have a couple of days were we will hit freezing temperatures and everyone freaks out (Pets, Plants and Pipes)
    -Do I need to cover (with pipe insulation) my exposed pipes comming from my pool equipment?
    -my jandy stealth pumps automatically turn on and will keep running if freezing temps hit (I'm guessing this is the built in freeze protection)
    Is there anything else I can do? We do not use solar covers in this area of Texas at least none that I have seen.
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Winterizing in ground pools in Houston,TX. Do Ineed to do anything special?
    It does not get cold enough down here ( I am in New Orleans ) to truly winterize your pool. Just run your pump when it gets below freezing. You freeze protection should actually do this for you. My Jandy only tipped the freeze protection once last year. You will need to stay on top of your chemistry year round. Your plaster will last much longer if you stay on top of the chemistry. I see you have an inline chlorinator. Are you using tablets? If so you need to read up on pool school and stop using them as your CYA will go through the roof. Saw your build by the way. Beautiful pool!
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Aug 2010
    Dallas, TX
    4,052
    I'm in Dallas and I never winterize or close my pool. The temps would have to get REALLY cold for you to have a problem, and we simply don't get that cold. Goign on 4 years now, no issues, and I was here when the whole "Super Bowl" winter happened.
    The good news is that everything goes in slow motion over the winter. Chlorine usage goes down to almost nothing.
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    Awesome, thanks Y'all. This has put my mind at ease.
    Yea I'm using an inline chlorinator, CYA is in check for now @ 30. I've noticed we get much splashout during swims and rainstorms adding much fresh water. I believe this has kept my CYA pretty low. I've been using pucks for at least 5 months now with no issues and I shocked twice so far using hypo (leslies). I did remove the nature two cartridge.
    Jul 2014
    Dallas/Texas
    14
    This helps us too-- just one more question or two: So, we continue to run the pump through the winter and manage the chemicals as needed-- I assume. Is a pool cover necessary in Dallas, Texas for the winter or does keeping it "open" mean business as usual? Would a leaf bagger be necessary? Just trying to figure this all out. The pool closing that is posted is for people in really cold climates--
    Thanks---
    16,500 gal, IG plaster, restoration January 2014; 1 HP Energy Flo pump, 48 sqft DE filter-Hayward ProGrid 4820, 360 Polaris Sweeper; Taylor Complete K2006 FAS-DPD; Timer
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Only reason you'd need a cover is for leaf issues if you want. I just keep mine skimmed off the top as they fall with a screen cover over the skimmer face to keep from clogging and run as normal. Just remember to run the pump when temps hit freezing or below.
