Results 1 to 10 of 10
Thread: Is draining the ONLY way to lower CYA?
    Sep 2014
    2
    Hello everyone. Many of my google searches kept leading me to this site, where the forum has been very helpful. Feeling very convinced, two months ago I switched over to TFPC and have been content with the results.
    At the beginning of the conversion (once I received my test kit), my CYA was probably around 90 and I tested and maintained the pool using Pool Math. I was pleasantly surprised when ~3 weeks later the CYA was about 45. Then about another month goes by and I noticed that I could not visually see that layer of chlorine at the bottom of the Liquidator. Tested and CYA was ~20. I've read all over this site that to lower CYA to acceptable levels was to drain.
    *I never did drain to lower CYA*
    The question: So did CYA drop because I stopped using the tablets and the normal evaporation/pool filling over time?
    Thank you in advance.
    ~20,000 gallon inground plaster pool, Pentair 3/4 hp Superflo, Triton II fiberglass sand filter, Hasa Liquidator, TF - 100 test kit
    38,237
    Re: Is draining the ONLY way to lower CYA?
    Welcome to TFP!!!
    CYA does not evaporate. A significant drop like that may mean you have a leak. Do you have an auto-fill on the pool that could be masking a leak?
    Or have you been getting a LOT more rain than I got in the NW side?
    Or have you been doing massive baskwashes?
    Nov 2013
    Fort Worth, TX
    112
    The only way I see that you could get your CYA that low would be to introduce a lot of new water. As Jantzengomez said, that probably indicates a leak unless you can think of something else that caused a whole lot of new water to be added.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,179
    Or, if your pool water eliminates CYA we need to bottle and sell it
    Seriously, as has been said. Water replacement is the only way it really could have gone down that much.
    Support the site
    rodog123's Avatar
    Nov 2013
    Pearland, TX
    308
    My CYA is holding steady at 30. Tested on my own and took to the dreaded Leslie's (just to compare) for testing ~ in the same ballpark.
    We get significant splashout from 3-5 kids getting in and out of the pool and with much rain here in Houston I believe this has kept my CYA down.
    I've been using pucks for 5 months no problems as of yet.....
    Completed 38'X21' IG Free form pool approx 18.5K gallons, sports pool w/spa and tanning shelf 3.5-5.5 ft. Jandy Cartridge Filter, Jandy stealth pumps, Jandy LXi Heater, I aqualink, Inline chlorinator. Click to see My Pool Build
    Sep 2014
    2
    I'm glad you responded jblizzle since I knew we are in the same city. I did deal with a leak back in April/May and determined it was a crack between the cool deck and space the auto fill comes in. I was fairly certain after my repair that I solved the leak. I would say the monsoon rain this season on the westside has been fair, not like the eastside of town.
    *This pool is at a rental house and when they received their 1st water bill it was over $200. This is what lead to the investigation. They wanted a credit so they provided the next 3 months of bills and each month it was lower. From $220 to $92 to $79 to $68. April thru July. I don't believe I have a water leak but I will do the bucket test again.
    I did a major sand filter cleaning a couple months ago during the conversion and the CYA was then at 45 and I was happy. Perhaps there a problem with my testing? I know how to follow directions that came with the test kit.
    Tink9305's Avatar
    Apr 2014
    14
    It sure would be nice if something other than a water change lowered CYA ) On the East side here but the rain didn't help my CYA
    14,000 AG 26' round 52"deep Hayward S166T92S Pro Series 16-inch 1-Horsepower Sand Filter
    Put up April 2014 TF-100 Test kit
    Being refilled Aug 31, 2014 due to needing to move, needing a 68% water change due to CYA, and to add support under legs
    Aug 2014
    Shallotte, NC
    693
    I found a reference on the Internet to "Peroxolyte", which is supposed to have some magical properties associated with lowering CYA.
    Any thoughts?
    30,402
    Any thoughts?
    Disregard it. Draining remains the only practical way.
    May 2014
    Franklin, NC
    9,179
    Quote Originally Posted by ewkearns View Post
    Any thoughts?
    it has been discussed a few times over the years. Here is chem geek's comment about the CYA claim from 2011
    Quote Originally Posted by chem geek View Post
    Because the product is a combination of a persulfate with cobalt ion and that this is known to produce very strong oxidation, it is possible that this can oxidize Cyanuric Acid (CYA). So their claim is at least plausible. However, such a strong oxidizer may very well oxidize swimsuits, skin, hair and pool equipment much faster so that would be a concern. As something to use when shocking or for Crypto or when fast oxidation is needed, it sounds reasonable, but for continual disinfection it might be too strong an oxidizer. Basically, one wants something that kills pathogens quickly, but isn't so strong an oxidizer as to affect things you don't want oxidized. This is very difficult to do, though many oxidizers, including chlorine and MPS, are rather selective. Chlorine with CYA seems to give a reasonable balance, though of course it has disinfection by-products.
    Anyone is welcome to try this by buying a small amount of the product and doing bucket tests for experiments. That's how we ultimately determine the validity of claims.
    No updated info was posted
    Support the site
