How to remove remnants of pool rail?
Aug 19, 2014
8
Jupiter, FL
Greetings All
When I bought a foreclosed house - they had to tarp the pool....unfortunately - they had to remove the pool railing - I guess the guys didn't have much patience to undo the bolts and lubricate/CLR the railing to wobble it out the concrete - it looks like they did a rough job cutting it and hammering down the sharp edges.... Any idea on how to get these out so I can install a new rail? Hoping I don't have to jack hammer :(
Images are here: http://imgur.com/a/yoSYV
Bob
Depends on what you're intending to put back as a replacement.
Something that bolts to the surface? - Just grind these off flush and fill the hole with concrete. Leave the steel in place.
Something that goes into the concrete? - You'll probably be renting a core drill to make holes for the new rail anyway, just core drill a plug out that includes these remnants.
If you really need the steel out, I think I'd work it with a chisel. Try to collapse the pipe in on itself to give yourself clearance to get it out.
-Denny
I was thinking to make things easier - it would be best to install the same rail that was there before - luckily it seems to be a pretty standard item:
http://www.amazon.com/Inter-Fab-D4D049-Mounted-Stainless-Steel/dp/B00436F7C8
Looking at the site more closely - I see they sunk in the standard bronze anchor into the deck:
http://www.amazon.com/gp/product/B00AOANUG2
Would chiseling cause irreparable damage to the bronze anchors? Any chemicals out there that could work at the corrosion/lubricate so I can pull the remnants out? Careful use of a pressure washer and 0 degree nozzle? Other ideas?
Bob
How to remove remnants of a pool rail?
Threads merged by moderator. Please do not create duplicate threads. Thanks, jblizzle
Reposted from: Pool Start-up and Closing
http://www.troublefreepool.com/threads/84918-How-to-remove-remnants-of-pool-rail
Greetings All
Images:
The railing would be the same type as was there originally
http://www.amazon.com/Inter-Fab-D4D0.../dp/B00436F7C8
Would chiseling cause irreparable damage to the bronze anchors? Use a screw drive and hammer between the tubing and the bronze anchor and try to compress remnant tubing? Any chemicals out there that could work at the corrosion/lubricate so I can pull the remnants out? Careful use of a pressure washer and 0 degree nozzle? Other ideas?
.... how I imagine the guy who did this to the pool rail.....
Thanks in advance!,
Bob
If it was me, I would use a rotary hammer(can be rented) with a 4 inch diamond hole saw, drill it down then chisel out. And as per what was mentioned earlier, buy new anchor and cast them into place (in the holes created by the hole saw) with a poly modified cement/sand mix. Shouldn't take more than 2 hours.
