Thread: How to remove remnants of pool rail?
    Aug 2014
    Jupiter, FL
    6
    Greetings All
    When I bought a foreclosed house - they had to tarp the pool....unfortunately - they had to remove the pool railing - I guess the guys didn't have much patience to undo the bolts and lubricate/CLR the railing to wobble it out the concrete - it looks like they did a rough job cutting it and hammering down the sharp edges.... Any idea on how to get these out so I can install a new rail? Hoping I don't have to jack hammer
    Images are here: http://imgur.com/a/yoSYV
    Bob
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    605
    Re: How to remove remnants of pool rail?
    You could use an angle grinder to cut it flush with the deck and then use a hammer and hardened chisel to cut a vertical line down the rest of the pipe. Then use some vise grips to pull it out.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Jul 2014
    63
    Depends on what you're intending to put back as a replacement.
    Something that bolts to the surface? - Just grind these off flush and fill the hole with concrete. Leave the steel in place.
    Something that goes into the concrete? - You'll probably be renting a core drill to make holes for the new rail anyway, just core drill a plug out that includes these remnants.
    If you really need the steel out, I think I'd work it with a chisel. Try to collapse the pipe in on itself to give yourself clearance to get it out.
    -Denny
    IG gunite 20k Gal (estimate), Nautilus NS-60 filter (D.E.), Single speed pump (unreadable nameplate - assume 1HP) on a crappy mechanical timer.
    And a worn-out Kreepy Kraully. TF-100.
    Aug 2014
    Jupiter, FL
    6
    I was thinking to make things easier - it would be best to install the same rail that was there before - luckily it seems to be a pretty standard item:
    http://www.amazon.com/Inter-Fab-D4D0.../dp/B00436F7C8
    Looking at the site more closely - I see they sunk in the standard bronze anchor into the deck:
    http://www.amazon.com/gp/product/B00AOANUG2
    Would chiseling cause irreparable damage to the bronze anchors? Any chemicals out there that could work at the corrosion/lubricate so I can pull the remnants out? Careful use of a pressure washer and 0 degree nozzle? Other ideas?
    Bob
    Aug 2014
    Jupiter, FL
    6
    Unhappy How to remove remnants of a pool rail?
    Threads merged by moderator. Please do not create duplicate threads. Thanks, jblizzle
    Reposted from: Pool Start-up and Closing
    http://www.troublefreepool.com/threa...s-of-pool-rail
    Greetings All
    Images:
    The railing would be the same type as was there originally
    Would chiseling cause irreparable damage to the bronze anchors? Use a screw drive and hammer between the tubing and the bronze anchor and try to compress remnant tubing? Any chemicals out there that could work at the corrosion/lubricate so I can pull the remnants out? Careful use of a pressure washer and 0 degree nozzle? Other ideas?
    .... how I imagine the guy who did this to the pool rail.....
    Thanks in advance!,
    Bob
    nofa93's Avatar
    Sep 2013
    Montreal, Canada
    46
    If it was me, I would use a rotary hammer(can be rented) with a 4 inch diamond hole saw, drill it down then chisel out. And as per what was mentioned earlier, buy new anchor and cast them into place (in the holes created by the hole saw) with a poly modified cement/sand mix. Shouldn't take more than 2 hours.
    20,000 Gallons Vinyl 16x32 Inground with Stamped concrete decking. Hayward Sand Filter. DIY Diaphragm pump injection system. K-2006C Test Kit.
    450 Gallons Standalone Acrylic CALSPA 2006.
    Canadians, Get your test kit here!.
