Results 1 to 19 of 19
Thread: Pool Renovation - Tucson, AZ
    May 2014
    Oro Valley, AZ
    120
    We decided to do major renovations to our pool. Here's a summary of the work to be performed:
    Resurface interior with Pebblesheen Blue Granite.
    Remove/replace all interior tiles and add handholds.
    Resurface decking.
    Remove/replace waterfall with new rock.
    Remove rock wall behind pool and extend planter 11'.
    Expand deck area near the west gate entrance making wrought iron fence go straight to block wall. Dirt to be excavated and new decking poured in that back corner.
    Drill hole in deck near skimmer to install auto-fill valve that will have a round skimmer type cover.
    Drill interior hole near skimmer to install a dedicated suction line.
    Replace light niche.
    Install 250W color logic light.
    Replace all drain and return fittings.
    Install new Hayward Ecostar variable speed pump.
    Replace 40' electrical run from house to filter panel.
    Here's the latest photo I have to be my before construction photo:
    Gil
    In-ground: 20,600 gallons; Sand Filter 1HP pump; Kreepy Krauler; Solar Breeze Solar Powered Robotic Skimmer; TFT-100 test kit
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Pool Renovation - Tucson, AZ
    Very nice starting point. This will be a fun one to watch.
    Best of luck on the Reno.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    May 2014
    Oro Valley, AZ
    120
    And to my surprise they actually showed up yesterday to drain the pool and started working this morning on the original scheduled start date. They started at 6:15am and by lunch time my wife sent me this photo....looks like they already chipped out the entire pool interior, removed all the tiles, and removed the waterfall.
    Gil
    cwescapexlt4x4's Avatar
    Jul 2014
    Litchfield Park, AZ (PHX metro area)
    461
    making good progress!
    Chris - aka cwescapexlt4x4
    (Build 8/26/14 - 10/17/14) in-ground Presidential Pools 15K gallon salt water pool Pentair Inteiliflo pump, Regal Blue Pebble, Clean & Clear filter, in-floor cleaning,
    LED light, 3' sheer spill, 2 benches, large Baja step. / Pergola by Booth Built 19W x 14D // Outdoor Kitchen, W/Primo grill and BBQ Coach kit for the island.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    wow, that was quick!
    May 2014
    Oro Valley, AZ
    120
    Yeah my wife said they started running 3 jack-hammers at 6:15am. It was so loud her and my daughter had trouble talking to each other inside the house. I'm the sure the neighbors weren't happy but at least the jack-hammers will only be run a day or two.
    Gil
    Jul 2014
    461
    it's AZ, workers have to start early... that's my explanation to my neighbors
    Oct 2009
    3,899
    They can probably understand that They do live here, after all.
    Jim H.'s Avatar
    Jun 2014
    11
    Fingers crossed that all goes as well as the start. That is a big job. Who is doing the work?
    9000 gal. IG plaster pool/spa, built in 2005. Cartridge filter, sta-rite system3 Model s8m150. Max flow rate 125 gpm. No SWG. 5 panel Heliocol solar heating system.
    May 2014
    Oro Valley, AZ
    120
    The pool builder for the renovation is Valley Oasis. I've really liked the folks I've dealt with there so far.
    The original pool was built by Patio Pools and Spas so we went to them first. After waiting for the first appointment to get here I left work early to be home and they were a no show. I called the next day and was told we weren't showing in their computer system even though I had an appointment card. So they rescheduled for the following Monday. Then on that day the guy called ready to come by four hours early so I wasn't able to be there so he came anyways and my wife handled it. The estimate wasn't bad but they didn't seem interested in the extra work we wanted done and my wife didn't really like the person that came to the house. The estimate was basically a few numbers and boxes checked on a checklist that I could have done in 10 minutes. The estimate we got from Valley Oasis you could tell had a lot more time and thought put into it and we both liked the person that visited to look over the pool.
    Gil
    May 2014
    Oro Valley, AZ
    120
    I have several photos showing some of the progress over the past month. Like most pool companies they tend to show up and do a bunch of work and then don't show up for several days but I haven't been sweating it since I knew I wouldn't be swimming in it this season anymore.
    Fence has been torn down and the rocks are being laid in place to build the new waterfall feature.
    Closer view of all the rocks placed for the new waterfall.
    Mortar is in place to lock in the waterfall rocks.
    Dirt removed for the new planter and deck area.
    Planter wall is built.
    Gil
    May 2014
    Oro Valley, AZ
    120
    And more photos of the renovation...
    Side view of the planter. In the corner I wanted this area to have the planter closed off to the wall so they agreed to come back to change that later.
    Most of the border tiles were laid today.
    New pump is installed with some of the plumbing modifications. I'm complaining about the 2 valves that aren't replaced because I thought they said that was included and if not I wanted to pay to have them replaced because it makes no sense to have 95% of the pool looking brand new and have these 2 valves and piping looking 25 years old.
    Electrical work started...the run from the house that was rusted out is being completely replaced.
    Gil
    38,299
    Can you even disconnect that pump if you needed to? With no pipe available, next time there is a problem you are going to have to replace the backwash valve too. Why not move the filter over 2 feet and have some space? Or they could have put the filter on the left. Too late now though. No idea why they always do this.
    May 2014
    Oro Valley, AZ
    120
    They just installed the pump where the old one was sitting. I'm not even sure how he had enough pipe to do this change out. When we had pump issues before I think they just changed out the rear end section. I'm hoping it will be many years before I have to worry about this piping arrangement. I can probably do any work that needs to be done. Heck I asked about getting the other 2 valves replaced and they wanted $350. That sounded a little high since its work I know I can do.
    Gil
    38,299
    The 2 valves are at least $100 themselves. Just paint all the pipe and valves and it will look fine.
    May 2014
    Oro Valley, AZ
    120
    Yeah the job supervisor replied and told me they were planning on painting all that plumbing to make it look new. I didn't know they were going to do that. So luckily they've been pretty good to work with because I'm realizing not every detail of what we wanted was detailed in the contract. Like it just said they would install an autofill in the deck but the contract didn't specify a location. We had verbally discussed it during the initial evaluation. So partway through I found out they were wanting to put it to the left side of my light niche because that is where they had already cut out a slice of my deck. So I was prepared to argue over the placement because that was going to place it in a higher traffic area and I wanted it to be over closer to the skimmer since there was already a skimmer plate in the deck over there and not as much foot traffic on that end of the pool. I was surprised when they responded "no problem we'll take care of that". A couple days later they cutout a small slice in the deck over near my shower head where we wanted it placed.
    Gil
    May 2014
    Oro Valley, AZ
    120
    Quite a bit of work was done this week. All the electrical work was completed and the new light installed. They ran all the new plumbing for the new suction line and installed the autofill. They formed up the new deck area and the concrete truck is here right now about to pour the decking.
    The new deck area about to be poured.
    The new autofill area about to be poured as well.
    The plumbing at the pump is completed and they painted it. I asked the guy doing the work and he said he could remove and replace this pump leaving the backwash valve assembly in place.
    Gil
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Thanks for sharing! This is going to be fun to watch!
    Kim
    Jul 2014
    461
    Nice progress and looking good!
