Results 1 to 8 of 8
Thread: fixed impeller now pump leaks where could it possibly be coming from?
    Feb 2014
    dfw tx
    67
    So fixed the impeller screw coming out by buying new impeller and screw it does't come out anymore. Now pool pump leaks. Somewhere between 1 and 2 when I fill up to start it up it starts leaking. Never leaked before is there a seal between them? or is it the pump itself that's leaking? Thanks this is beyond aggravating in the last week this is the 3rd thing that has gone wrong with this pump.
    16k gallons
    IG "roman style" plaster
    Pentair CCP420 Clean and Clear Plus Pool and Spa Cartridge Filter, 150-GPM
    1hp pump
    Built in 2000
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: fixed impeller now pump leaks where could it possibly be coming from?
    Did you change the seal? With that type of problem is was likely damaged at some point.
    Mark
    Shaft seal is probably where your leak is coming from.
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    Feb 2014
    dfw tx
    67
    Quote Originally Posted by btolley View Post
    OK ordered it thank you so much hope it fixes the problem finally
    16k gallons
    1hp pump
    Built in 2000
    Feb 2014
    dfw tx
    67
    Changed seal still leaking, made sure it was installed good and put magic lube all over the rubber parts. What else could be leaking?
    16k gallons
    1hp pump
    Built in 2000
    Smykowski's Avatar
    Sep 2011
    3,065
    Any of the o-rings damaged/improperly seated?
    Feb 2014
    dfw tx
    67
    Not that I could tell pulled it apart again just to be sure, made sure the top piece went into the bottom piece but beyond that not sure.
    16k gallons
    1hp pump
    Built in 2000
    mas985's Avatar
    Pleasanton, CA
    11,741
    Sometimes there can be hairline cracks in the housing but they are difficult to find.
    Mark
