Thread: Speedstir Mixer "Pill"
    Mar 2014
    Mesquite, Texas
    29
    I lost the little metal "pill" that goes with the speedstir? Can I just reorder one or do I need to order a whole new one?
    14K IG Aggregate Mini Pebble, 1 HP Hayward Single Speed Pump 120 GPM, 175 Sqft Cartridge Filter
    In-Line Chlorinator, 360 Polaris Black Max, Sheer Descent Water Feature. TF-100 Test Kit
    Build Date 2/1994; Remodel Date 4/2014; Original Owner, North Texas
    May 2014
    Pflugerville, TX
    148
    Re: Speedstir Mixer "Pill"
    You can order a 1" stir bar on a lot of sites.
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    tftestkits.net has just stir bars, or you can look elsewhere online as well.
    Isolated Spa - 345 Gallons
