Thread: New pool fill Test Levels Help Please
    Tink9305's Avatar
    Apr 2014
    14
    We used liquid stabilizer last night, Not sure how long it takes but here are the numbers tonight.
    Haven't added anything yet tonight.
    What order should I add things to finish balancing it out? Thanks!!!
    FC 3
    CC 0
    pH 7.8
    TA 130
    CYA I think about almost 20
    14,000 AG 26' round 52"deep Hayward S166T92S Pro Series 16-inch 1-Horsepower Sand Filter
    Put up April 2014 TF-100 Test kit
    Being refilled Aug 31, 2014 due to needing to move, needing a 68% water change due to CYA, and to add support under legs
    38,419
    Re: New pool fill Test Levels Help Please
    The liquid CYA should register almost immediately. What level were you targeting? I would suggest that you fairly quickly raise the CYA up to 40-50ppm and then just maintain adequate FC and keep the pH in the 7s.
    Tink9305's Avatar
    Apr 2014
    14
    Thanks!!! We were trying for 40, it's kinda strange because last time we put the exact thing in and it was at 40
    nofa93's Avatar
    Sep 2013
    Montreal, Canada
    46
    Give it a bit more time to register, retest and then consider adding more. Something you don't want to overshoot.
    20,000 Gallons Vinyl 16x32 Inground with Stamped concrete decking. Hayward Sand Filter. DIY Diaphragm pump injection system. K-2006C Test Kit.
    450 Gallons Standalone Acrylic CALSPA 2006.
    Canadians, Get your test kit here!.
    30,431
    I am not sure there is a need to add anything? What does your water look like?
    Naturally, your FC will need to be replenished constantly. Have you read "The ABC's of Pool Water Chemistry" up in Pool School?
