Thread: Wasp nest being built under each end cap
    Smile Wasp nest being built under each end cap
    Is there a company that makes an under cap To seal the rail so wasp cannot build a nest? I just tried a friends idea of using steel wool under each end cap to prevent access to build a nest. Will not know if it will work for a few days.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,197
    Re: Wasp nest being built under each end cap
    Not sure if it will work, but steel wool and water usually = rust. Around boats we always used brass wool to,eliminate rust stains.
    Support the site
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    You can also try spraying under the cap with WD40. A nice, oily film should discourage nest building.
    Love TFP? Become a
    TFP Supporter!
    Jul 2014
    Pocahontas/Il
    4
    I filled mine with expanding foam. Be carefull.
    24x54 AG. Sand filter. K2006 Test Kit
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    If using foam, you can get the window and door kind that doesn't expand with great force. Still messy, but it won't warp anything of that's an issue.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    May 2012
    Montville NJ
    545
    I had birds under one of mine. (yeah, a bird build a nest and had babies)
    I stuck wadded up plastic (not metal) window screen all up in there - that won't rust either - and is cheaper than brass wool.
    -dave
    27' Round ABG (17,000 gal) - +/- 11 hours of full sun per day
    Hard plumbed Hayward Perflex EC-40 DE filter w/ 1 HP pump (Got a new one June 2015)
    Filered 4 hours per day (on a timer)
    Pentair Aqualuminator - now working - and now dead once again, this time for good.
    Zodiac Wahoo
