Thread: CYA Testing - Taylor 4088 Movable Dot vs Standard Vial Test
    Jul 2012
    Dallas, TX
    179
    Does anyone use the Taylor 4088 movable-dot testing vial for CYA testing?
    Is it more accurate overall, vs the standard vial test (adding reagent until the stationary dot disappears)?
    [edit]
    I just found this thread:
    http://www.troublefreepool.com/threa...Test-View-Tube
    From reading this thread, more reagent is required for the 4088 testing vial. I guess it's not worth it to get the 4088 vial after reading the thread.
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    Oct 2013
    Chapin, SC
    1,141
    Re: CYA Testing - Taylor 4088 Movable Dot vs Standard Vial Test
    Inadvertently duplicated when editing. But just noticed-- you mix the pool water and reagent before you put it in either test. The 4088 doesn't have a seperate mixing bottle.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Oct 2013
    Chapin, SC
    1,141
    It IS easier to use, but it does use a lot more reagent. So, I bought a 16 oz bottle of it directly from Taylor for less than a 2 oz bottle I bought locally when I ran out of it trying to get my cya down to a reasonable level. I since have gotten much better at using the test block that came with my k-2006 so I don't use the 4088 much anymore.
    Btw, testing and dosing fc daily should keep you from ever having to shock.
    Jul 2012
    Dallas, TX
    179
    Thanks for the info. I'll stay with the standard CYA testing tube, black dot at bottom.
    Since discontinuing the Chlorinator use with Trichlor tablets in June (2014) and dosing with Bleach, the pool's been in great shape.
    Last Shock with Cal Hypo was June 12 2014.
    My last D.E. Backwash was May 15th (2014). That's the longest I've gone between Backwashes during the swimming season.
    CYA is dropping although I know it'll be a slow rate without partially draining the pool. I'm tracking the CYA reduction rate, testing about every 3 months.
