Thread: Removing Diving Board Bolts
    Aug 2014
    Canton
    1
    We just took out a very old diving board, but now have the four bolts sticking out of the concrete patio. Any suggestions for removing them? A saws-all has been recommended, but I'm hoping to get them as flush to the ground as possible.
    Thanks!
    38,475
    Re: Removing Diving Board Bolts
    Welcome to TFP!!!
    An angle grinder will allow you go cut/grind them off flush to the concrete.
    May 2013
    Fort Lauderdale, FL
    423
    If you're only going to use it once... http://www.harborfreight.com/heavy-d...der-91223.html
    Or if you want it to last, spend $100 and get a Milwaukee or Dewalt one.
    Get a 1/8" thick cut-off wheel to cut the bolts, then a thicker grinding wheel to grind them flush.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Aug 2010
    Dallas, TX
    4,052
    I have that same angle grinder and use it all the time, I have had it 4 years. Pretty surprising how long they will last.
