Results 1 to 8 of 8
Thread: GVA-24 Parts
    Sep 2014
    TAMPA
    5
    GVA-24 Parts
    Just curious from you experts out there. I've had one of my 4 hayward GVA-24 fail. The motor is perfectly fine but the gears (2 of the three gears) are stripped to some extent. The valve will still sort of turn but not really.
    Anyway, In my googling I've seen lots of instances of failures due to gears stripping either on the actuator motor itself or the actual gears (my case). Does anyone know where one can find replacement parts for these things? or used units we can purchase for their parts? It's a shame to have to replace these expensive units for a set of easily replaceable gears. etc..... I tried the normal spots like 'ebay' and I even asked Hayward (I'm expecting a NO from them).
    Thanks everyone. Glad to be a new member. I've used this site for 2 years since I've installed my pool and it has been far better than any information my pool company gave me. THanks again.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: GVA-24 Parts
    Welcome to TFP!
    Do you have dimensions, shaft size and tooth count for the gears? Someone may know a non-pool equipment source for replacements.
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: GVA-24 Parts
    I have not yet found any place that you can buy just the gears from. I have always had to replace the entire unit.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Sep 2014
    TAMPA
    5
    Re: GVA-24 Parts
    Quote Originally Posted by JohnT View Post
    Welcome to TFP!
    Thanks for replying John. I do not have the dimensions. I can measure them but I am thinking it would be quite a bit of measurements as these seem very custom gears built for these controllers. I'd prefer to stay away from obtaining gears unless they were made for this application otherwise I might end up paying for gears that were just slightly under/oversized... It's a shame that Hayward stopped selling these parts. They used to sell them but of course why would they want people fixing their products when we can buy new ones. (If I end up replacing it, i'll buy a cheaper brand anyway).
    SW Indiana
    9,199
    Re: GVA-24 Parts
    Quote Originally Posted by calisro View Post
    I'd be surprised if Hayward custom produced the gears. There are manufacturers who make standardized parts, and it's usually cheaper to design around those parts if you can. Here is an example of one company http://www.qtcgears.com/rfq/spurgears.htm
    Sep 2014
    TAMPA
    5
    Re: GVA-24 Parts
    True John. Also, I've found that Hayward did once sell these. Evidenced by this link:
    http://products.1800pools.com/haywar...b_10798233.php
    But doesn't look like they do any longer. (not surprised).
    Sep 2014
    TAMPA
    5
    Re: GVA-24 Parts
    That is an interesting site. I'll measure mine and see if any line up. If I do find some on that particular site (or similar site) i'll post here for others.
    Sep 2014
    TAMPA
    5
    Re: GVA-24 Parts
    I've done a little research here but frankly finding a gear to fit would be an exercise in futility. There are too many measurements and too many types of gears. I'll likely just try to find a used actuator with a burned out motor that I can swap the gears on unless someone comes forward with information on replacement parts.
