Results 1 to 18 of 18
Thread: Token Expired
    Mar 2007
    San Rafael, CA USA
    12,082
    Token Expired
    After the move to the new forum software earlier this year, I have been sometimes getting the following message:
    Your submission could not be processed because the token has expired.
    Please push the back button and reload the previous window.
    Trouble Free Pool
    Though I'm able to recover by the suggested reload, if this occurs after writing or editing a post then going back from this message usually loses everything that was typed (just from the "Back", obviously the "reload" will get rid of it but it could be copied before that) so it can be very frustrating.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: Token Expired
    I find if I go to "Go Advacnced" before replying it doesn't happen. That or if you get the message "copy" your reply and go to the top of the page and hit the link under "+ Reply to Thread" that has the threads name and then paste your copied message in.
    Solar Blanket, Well Water, Borax Added. 76
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Token Expired
    I have yet to see that one.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Token Expired
    Which browser are you using?
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Token Expired
    Safari 7.06 on Mac OS 10.9.4
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,109
    Re: Token Expired
    Richard,
    Can you please explain what you were trying to do when you received this message? Was it uploading a photo or another action??
    Kiss4aFrog,
    Are you getting that message on a Mac as well??
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Token Expired
    I get that same message occasionally when I use the bookmark I have to go directly to my "Settings" page. I figured it was a problem with IE8.
    Re: Token Expired
    I don't yet have any clue about what is causing this issue.
    However, what you have typed isn't usually lost even when things like that happen. You should be able to go back to the same page and look closely for the "Restore Auto-Saved Content" button towards the bottom left of the reply box. Pressing that button will usually recover whatever you had typed before things vanished.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Token Expired
    I don't see any "Restore Auto-Saved Content" button in either the regular nor Advanced reply boxes.
    As for what I do when this happens, I'm just posting a reply.
    Jul 2009
    Houston, Texas
    9,427
    Re: Token Expired
    I've been playing around with the auto-saved feature. It seems to like the message I was going to post this morning better than the 3 I have tried to post this evening.
    As you type you will see a yellow "auto-saved" message flash in the bottom right corner of the dialogue box. Once you use the browser's forward and back buttons to navigate away from a page, anything you typed in the reply box but did not post will be available for restoration when you click in the "restore auto saved content" box imbedded in the lower left corner of the reply box. The box is only visible and active after you navigate away from the page and come back without completing the post.
    My suggestion this morning that I did not post was "Check your security settings, clear the cache, and delete the cookies. You may want to delete any temp files also." Didn't seem to matter what I typed since then, it would only save and restore that 1st attempt to post.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Token Expired
    NOW I see the "Restore Auto-Saved Content" button. I didn't see that earlier when I posted. Thanks for explaining that the button only shows up after some typing and auto-save. That makes sense. So if the issue happens again where I have to go back, I can at least recover what I've typed.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Re: Token Expired
    I have noticed that little " Auto-Saved" box pop up now and again while typing and now I guess I know what it's for !!
    Leebo: I'm using Firefox on a windows platform. It doesn't happen very often and it might be I'm in the screen too long. Read the post, do some research, look for a picture ... that kind of thing.
    Jul 2011
    Eastern Ohio
    7,109
    Re: Token Expired
    Thank everybody for chiming in on this. I'm searching around the net, and I'll post back once I figure out something.
    Jul 2012
    Whidbey Island, WA
    398
    Re: Token Expired
    was perusing jblizzle posts last night
    put computer to sleep
    awoke computer this morning
    saw the message
    is discussed on the vBulletin Forum
    one post said upgrade to 4.2.2 but this is 4.2.2 so ???
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Jul 2011
    Eastern Ohio
    7,109
    Re: Token Expired
    Did you refresh the page first, or go right into an action (IE post reply that was already pre-typed)?
    Jul 2012
    Whidbey Island, WA
    398
    Re: Token Expired
    Quote Originally Posted by Leebo View Post
    did not refresh first
    was not doing a reply so there was no reply window, just the screen from http://www.troublefreepool.com/members/12859-jblizzle
    what did I do? hard to recall but is likely I clicked on a link
    sort of like my privileges to use that page and links thereon had expired
    I suppose could be tested by going to a page, putting computer to sleep, waking in say 10hrs (a pain)
    but could try it tonight
    Jul 2012
    Whidbey Island, WA
    398
    Re: Token Expired
    well, at least it is reproducible
    same thing this morning
    1) go to jblizzle page
    2) put computer to sleep
    3) next morning wake computer
    4) put cursor over a link and > the message
    turns out no need to refresh the page, just click Ok and all works fine
    MacOS 10.9.4 Safari 7.0.6
    Jul 2012
    Whidbey Island, WA
    398
    Re: Token Expired
    one more thing
    discussions of this issue on the web go back at least 6 years
    would suggest no quick fix
