Results 1 to 16 of 16
Thread: Hayward thru the wall wide mouth skimmer installed on Intex Ultra Frame Rectangle poo
    Aug 2014
    oxford/GA
    23
    Just wanted to share our thru the wall skimmer install. We had minimal water loss and didn't lower the level for the install. We had two people, one in the pool and one outside of the pool. We split the butterfly gasket in half with a razor blade. The inside person used an awl to puncture through the wall of the pool and then pushed the screws through the faceplate, gasket and into the holes. The outside person then held the already assembled skimmer in place while the inside person tighted all of the screws. Once we had averything tightened up, we attached the Intex hose to the PVC added to the skimmer. It was at this point that we used a razor blade to make the final cut and removed the piece of liner inside the mouth of the faceplate. No leaks and it seems to be working great. So glad we did this.
    12x24x52 Rectangle Intex Ultra Frame AGP with 1,600 gal. per hour Krystal clear sand filter and saltwater system combo pump.
    May 2012
    Boyd, Texas
    93
    Re: Hayward thru the wall wide mouth skimmer installed on Intex Ultra Frame Rectangle
    Always nice to hear it go smoothly. I just received my skimmer today so my install should be soon.
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
    jmcdtucson's Avatar
    Jun 2014
    317
    Just came home my floating skimmer had come loose and my pump was sucking air for who knows how long. Ordering this today:
    http://www.amazon.com/Hayward-SP1091...dp/B002KMIK26/
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Aug 2014
    oxford/GA
    23
    Quote Originally Posted by jmcdtucson View Post
    This is the exact one I ordered. It installed so easily.
    Aug 2014
    oxford/GA
    23
    We were afraid of pushing the screws too hard thru the liner and causing a split so we put pressure and kind of screwed them into the liner. It looked very odd from the outside seeing those 14 screws with water dribbling around them but they stopped the water enough to finish the work. I then hung the outside gasket on the screws and we backed the screws back out so they were just barely hanging on and then pushed the skimmer against the pool while my husband screwed the screws into the skimmer. Even though we started with the faceplate flush up against the white part of the liner, it pulled down a bit when all was said and done. We can still see the line sandwiched between the outside piece and inside piece so I think it's all good. Time will tell.
    kpierron's Avatar
    Jul 2015
    Ocean Springs, MS
    2
    Hi just wondering if once you installed you wide mouth skimmer did your skimmer stand straight up and down? Ours is having a lean to it... The wall of pool which is exactly where yours is installed is straight looking at it from the side! Very frustrated at this point. Can you be of any assistance with this matter?
    Thanks, Kim
    By the way we have changed pools from 26x52 to the 12x24x52...
    I need to change this info on profile.
    Kim
    AG 12x24x52 Intex Ultra fram Vinyl, 8405 gallons, Intex 1600 GPH Sand filter, Intex SWG, Hard piped W/ pvc, Hydro Pro wide mouth skimmer, Intex magnetized lights x2. Setting up in August, 2016! Mississippi Gulfcoast, Ocean Springs, MS. - Kpierron
    Jun 2015
    Stockholm, Sweden
    250
    Due to the shape of the liner, the skimmer will sit at an angle. That is OK, it doesn't affect the performance of the skimmer as long as you make sure there is enough water in the pool. I keep the water level at 2/3 up the skimmer at all times.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    Jun 2015
    Stockholm, Sweden
    250
    I have my skimmer plumbed in parallell with the original outlet. That way there is no risk of the pump sucking air if the water level gets too low.
    Jul 2015
    Charter Oak, California
    273
    Mickelin....you're really high with the skimmer. Any trouble with leaks? Sorry to horn in on your thread, trailbuddy69..
    Bob (AKA Schnozz)
    12 x 24 x 52 Intex Ultra Frame AGP, 8600 Gal; Pentair 2HP/2SP 150sqft Cartridge Filter; Hayward Through Wall Skimmer; Intex Automatic Cleaner (Fantastic); K-2006 Test Kit; Start-up 07/30/2015. First Time Pool Owner in SoCal.
    jmcdtucson's Avatar
    Jun 2014
    317
    Quote Originally Posted by kpierron View Post
    Thanks, Kim
    Kim
    Glad I read that last bit, you might want to update your signature. Yes, since the wall of the rectangular pool is not vertical, the skimmer is at an angle. It's not a problem for skimmer operation, but you do have an inch or so less leeway to let your water level go down since the skimmer tips up as it goes back.
    I also plumbed my skimmer in parallel with the other outlet so if the water gets too low for the skimmer or skimmer gets plugged, it can pull water from the other outlet.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Jun 2015
    Stockholm, Sweden
    250
    Quote Originally Posted by Schnozz View Post
    No, works perfectly with no leaks and no waterloss. I totally recommend mounting as high as possible.
    Jul 2017
    Colorado
    86
    Apologies for dragging up an old thread but what is the size of the output connector on this unit? It's not standard 2" PVC. Thanks.
    Jun 2015
    Stockholm, Sweden
    250
    Standard 1.5"
    Jul 2017
    Colorado
    86
    Quote Originally Posted by Mickelin View Post
    Standard 1.5"
    Cool. Yea....I found the internal threads. What are the external male threads for?
    Jun 2015
    Stockholm, Sweden
    250
    If you mean the included adapter that screws into the skimmer, that is used if you want to attach a hose with clamp. If you want to hard plumb, you need to buy a 1.5" adapter that you glue onto your pipe.
    Jul 2017
    Colorado
    86
    Yea...I was referring to the main connector on the bottom of the skimmer. There are both internal and external threads. The internals are 1.5" and I found an adapter for it. What are the external threads used for?
