Thread: Question about the R-003 reagent and the FAS-DPD Chlorine test
    Apr 2014
    Jamison PA
    15
    Ok, perhaps a completely silly question, but I had an interesting situation yesterday when doing my chlorine water testing. I use a TF-100 test kit. I was performing the FAS-DPD chlorine test, when I got distracted after adding the 5 drops of the R-003 reagent (having a newborn will do that to you!). So after I tended to my son (briefly- less than 5 minutes) I came back to a pink sample! It took 1 drop to clear. I can say it took awhile to get pink it was definitely clear after I added the drops and clear while I was washing my hands before getting the boy. My test kit is new (just a new pool owner this year), and the rest of my numbers were as follows:
    FC 12
    PH 7.5
    TA 70
    CH 225
    CYA 60
    Salt 3800
    I know my FC level is a bit high given the CYA level- I turned down the SWG right after getting the sample. I can't imagine there much in the way of CC's actually in the pool.
    So, is my CC level actually .5, or is there something with leaving the reagent in the sample for awhile that just eventually turns it back pink?
    Usually I don't wait more than 10-15 seconds before dumping the sample if it shows no color change. Should I be waiting longer? Am I being too darn anal retentive over possible .5 CC ?
    Thanks again for your help and everyone's contributions to the website! It's been really useful reading everything, and I've gone my first summer with no algae blooms and the cost of about 1/2 a gallon of MA.
    Mike, Bucks County PA
    13,500 gallon fiberglass Viking "Triton" pool installed 2013, 1.5 HP Pentair Whisperflo single-speed pump
    Pentair cartridge filter, Pentair IC20 SWG, iRobot Mirra 430 robot
    TF-100 + Speedstir - and so glad I found this site before I started!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Question about the R-003 reagent and the FAS-DPD Chlorine test
    That will always happen if you just let it sit with the reagent. Test is meant to be completed quickly for this reason. Your CC is 0.
    Isolated Spa - 345 Gallons
    Apr 2014
    Jamison PA
    15
    Awesome! Thank you!
    Oct 2013
    Chapin, SC
    1,141
    Yes, it should turn pink almost immediately when you add the r-0003. Then after you add whatever drops of r-0871 it takes to turn it clear, don't wait to empty the test vial or it will turn pink again.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    R-0003 contains iodide, which can be oxidized to iodine by oxygen in the air. The iodine reacts with reagent R-0870 to give the pink color.
    Support the site
    Wildcat's Avatar
    Jun 2013
    309
    When I do the CC test it clouds a little but doesn't turn pink. If I add a drop of R871 it turns clear. Zero CC or .5 CC?
    10000 Gal, IG Pebbletec, pop up cleaners,Hayward EcoStar VS, 425 sq ft Hayward Cartridge, waterfall feature
