Thread: Pool dosage calculator
    Aug 2014
    New York
    2
    Post Pool dosage calculator
    I am new to this forum, i just wanted to see if are any excel sheets to input test results and obtain the chemical dosages needed. I saw some links to websites, but my backyard is big and wifi is not reaching all the way to the pool. Any link or excel sheet is appreciated.
    38,474
    Re: Pool dosage calculator
    Welcome to TFP!
    Why not calculate the dosages inside? Usually good to do the testing inside anyway. Or you could save a local copy of the recommended PoolMath.
    Aug 2014
    New York
    2
    Thanks Jason for a quick response. I store all chemicals in the shed all the way back, it will be nice to get dosage information right away so I don't need to walk back inside. A friend of mine used to have excel on his tablet, and that may be useful for me
    38,474
    There are apps you can buy.
    Btw, the test kit and bleach should not be stored outside in a shed as the temperature affects them. That is why I said testing is usually done inside .... That is where the test kit should be stored.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    There is a great spreadsheet here: http://www.troublefreepool.com/threa...l-spreadsheet)
    PoolPal is also a free app that works fairly well.
    Isolated Spa - 345 Gallons
