Results 1 to 19 of 19
Thread: It all started with a sparkly pool and a green spa...
    Sep 2014
    The Woodlands, TX
    12
    For three years I have been caring for my pool using the BBB method and you have no idea how much I appreciate the knowledge you have shared. I had never had any trouble but I am now stumped and hope you will share your insight. I do ask for your patience as I may not be as well-versed when it comes to equipment terms. Apologies in advance for the length of the post.
    Our pool has a spa with a spillway, and while we swim regularly, the spa is seldom used (and I must admit is neglected at times with leaves sitting at the bottom for longer than should be). Yesterday our pool was its sparkly self when I noticed patches of algae on the walls of the spa. I proceeded to shock the spa as per Pool School protocol, but thought it best to turn off the filter pump to the pool and turn on the spa mode only- I figured it was easier to shock the contained spa water. The numbers were as follows:
    20,000 gal. Pebble Tec (Houston area)
    FC: 4
    CC: 0 (pool)
    pH: 7.4
    TA: 90
    CH: 250
    CYA: 30
    Water Temp: 89 / Cloudy Weather
    TFT FAS/DPD chlorine test
    Taylor K2005 for everything else
    Confession: I only tested the pool water; I did not test the spa. I just assumed that I needed to raise the chlorine to 12, so I proceeded to add bleach to the spa, however, when I tested the spa water after dosing, it showed a FC of 0, and CC a dark amber (I figured it would be useless to waste reagent to try to figure out what it was). I thought that the bleach was used up by the algae, so I added more. I kept testing, and adding more and more. The spa water became clear, but yellow, while still testing at 0 FC, and still amber CC. I then became concerned that I had added way more bleach than I should have for such a small volume of water (9ft round spa) so since the water was clear (albeit yellow), I returned to regular pool mode. I tested the pool water at this time and it gave me a reading of FC: 30 (!). While I was concerned at how the chlorine had gone up in the pool, I was relieved knowing that at least the level would be high enough to do away with any organics spilling from the spa. However, I tested again one hour later and the FC was 0 (!!), and CC amber. I just tested and indeed FC is 0, CC somewhat lighter yellow color. The spa now looks back to normal, the pool is clear; it is hard to gage the color since the sun has gone down, but it looks very slightly green.
    Please give me your impressions on how you think I should proceed. Are the FC/CC readings off because of the ridiculous amount of bleach I added? Or do I trust that in fact my pool water has 0 chlorine and organic matter in it? Could the FC really have swung from 4 ppm to 30 ppm and then to 0 ppm? If I added bleach to the spa only, how did it get to the pool?
    Thanks for your help.
    Sep 2013
    Connecticut
    728
    Re: It all started with a sparkly pool and a green spa...
    Are all the FC and CC levels you mention measured with the FAS/DPD test? It doesn't sound like it, since you mention an amber color, and the only color that show up in the FAS/DPD test is pink... were those tests perhaps done using the DPD test, which I think is part of the 2005 kit? My recollection is that that test bleaches out (no color) when you get much above about FC 5, so it is not good for measuring high chlorine levels. If you added a lot of bleach, you were probably above the range of the test.
    See post #3 in this thread:
    http://www.troublefreepool.com/threa...Kit-Directions
    Or, were you using an OTO test for most of your readings, which does go from yellow, to darker yellow, to orange as chlorine levels go up (not sure, though, how that particular test would give you FC 0 values)?
    Was the one reading of FC 30 obtained with the FAS/DPD test?
    I'm a relative novice at all this, so perhaps I'm missing something very obvious, but your description of test results seems unclear as to which chlorine test you were using.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Sep 2014
    The Woodlands, TX
    12
    Thank you for your reply singingpond. All chlorine tests (including the 30 ppm result) were done using the FAS/DPD from TFTestkits, and the color was definitely yellow.
    I am now thinking that perhaps what is happening is what chem geek (Richard) described in an old thread, where lack of FC in the spa caused bacteria to grow, it converted CYA into ammonia, and that the high demand for chlorine is due to the chlorine oxidizing the ammonia. I happened upon that post much too late last night, and unfortunately I cannot address it until late afternoon today. I plan on getting an ammonia test from the pet store, and re-testing the CYA. Hopefully if I can still register ammonia and see a drop in my CYA, the mystery will be solved. I think (?!)
    38,271
    The FAS-DPD test is where you add powder to the water which would make it pink if there was chlorine in the water and you then count drops until the water is clear. There is no yellow/amber.
    The yellow color-matching test that is by the pH test is the OTO chlorine test and generally only shows you the total chlorine level.
    Does you spa water not mix with the pool water? I would set you valve such that the spa is always mixed so that you only have one body of water to deal with maintaining.
    At this point you need to follow the ShockLevelAndMAINTAIN Process on the whole pool/spa I would think.
    Sep 2014
    The Woodlands, TX
    12
    I've been using the FAS-DPD for three years so I am familiar with it. Upon adding the heaping scoop of powder there is a tinge of pink which disappears in seconds- even before I swirl to mix. It is when I add the R-0003 DPD #3 reagent to detect CC that it turns yellow... and I mean yellow (no doubt about it).
    The spa and the pool water do mix. Thus adding to my confusion.
    I have "SLAMed" successfully in the past (twice, I'm embarrassed to admit). I am stumped now because no matter how much bleach I add, it still is not registering, certainly not anywhere near shock level (12 for my CYA of 30); this had never happened before. That's why I was thinking the bacteria-CYA-ammonia situation was happening.
    38,271
    If the FC level is high, you may not be adding enough powder to start. If you see pink and it goes away, I think you need to add a second scoop.
    How old is your kit? I have never seen the water turn yellow in the FAS-DPD test.
    Sep 2014
    The Woodlands, TX
    12
    I got the kit for the beginning of summer, and it is kept indoors in the shade. The weird thing is that when tested the pool water (before I started trying to raise the FC) it was 4; right before I opened up the spa to mix with the pool water it was 30 (remember I initially had it on spa mode only thinking it would be easier to shock); and when the water mixed it was 0. I have no reason to doubt the test. In the meantime, given the situation, I continue to add bleach, even though I cannot get the chlorine to register.
    But at this point it can't hurt.... I will try the second scoop!
    Sep 2013
    Connecticut
    728
    Certainly sounds mystifying! Maybe worth using an OTO chlorine test as a sanity check -- it would at least tell you if you have some chlorine, lots of chlorine, whatever -- a ballpark idea anyway.
    You say you have no reason to doubt the FAS/DPD test... but, weird results and unusual colors from the reagents (the yellow/amber shades you describe) would certainly make me doubt the test in my hands. I'll be curious to hear if adding more of the powder will give you clearer results.
    Sep 2014
    The Woodlands, TX
    12
    Thanks! In the meantime, would any of you please look at this post from chem geek and see if you think this is a possibility? It is the only thing I can think of, and I guess as he said... if it happened to him, it can happen to anyone!
    http://www.troublefreepool.com/threa...CYA-gt-Ammonia
    38,271
    It is possible, but you would likely be showing high CC levels and thus far you do not seem to have any believable FC and CC numbers posted.
    Sep 2014
    The Woodlands, TX
    12
    Could the amber color be "through the roof" CC levels? That is the only level that I would consider not believable, since I stopped adding the R-0003 DPD #3 reagent because it was not changing color at all.
    After the initial posted numbers all I have checked is the FC level and again, it continues to show 0 (even this morning). I will do a full set of numbers as soon as possible, but I hope you understand that I am reporting what I am seeing.
    38,271
    The FAS-DPD test should only ever be pink. You also should only add 5 drops of the R-0003 for the CC test and then add R-0871 to count the drops.
    The most logical explanation for this is that the yellow capped R-0003 reagent for the CC test got switched with the other yellow capped R-0600 reagent for the OTO test. Using the R-0600 would turn the water yellow.
    Sep 2013
    Connecticut
    728
    Quote Originally Posted by poolinthewoods View Post
    ...I thought that the bleach was used up by the algae, so I added more. I kept testing, and adding more and more. The spa water became clear, but yellow, while still testing at 0 FC, and still amber CC...
    Just wanted to double check on this -- you mean that the whole volume of water, in the spa, took on a yellowish color as you added more bleach?
    Sep 2014
    The Woodlands, TX
    12
    jblizzle- not a bad idea to be extra careful; I will be vigilant when I check next.
    singingpond- Indeed. The water in the spa turned yellow after adding bleach trying to get it to shock level.
    38,271
    The spa turning yellow could be a sign of some metal in the water ... high FC levels could make it visible. But, that is getting off subject.
    Sep 2013
    Connecticut
    728
    Well, I'm curious -- did you ever figure out what was going on with your test results?
    Sep 2014
    The Woodlands, TX
    12
    Thanks for the follow up singingpond. Truth be told, I hesitated in posting the numbers since if I was the reader, I would probably not believe them either. So here goes nothing. Please note that I was careful with the testing and I am sure no errors were made.
    After my last post, the FC levels continued to show 0 and so I continued trying to get it to register by adding more and more bleach (8.25%). On 9/2 the morning reading was STILL 0 so I added 3 more gallons (total 16 by now since the beginning). That evening's test showed a FC of 40. That's right. Forty (80 drops of R870 x 0.5). I then started to panic, thinking surely I was going to melt some pipe somewhere and started adding fresh water trying to dilute it. By the way, the CC test was still showing yellow. And yes I added the correct reagent. Due to life, I never made it to the pet store for the ammonia test. I did not sleep that night. 24 hours later (last night) the test is as follows:
    FC: 12
    CC: 0 (completely clear- no yellow, no pink)
    pH: 7.7
    TA: 120
    CH: 250
    CYA: 0 (clear)
    I think I got too caught up chasing the 0 FC and neglected to step back and look at the bigger picture after adding so many gallons of bleach. I am guessing I may have had algae and bacteria in the spa, and somehow it did not spill onto the pool (perhaps bacteria in the plumbing?). I do believe some of what was described by chem geek (in the link I provided) was happening since my CYA is now gone. I think I overwhelmed the pool with the bleach (for the initial CYA of 30, shock would be 12 ppm), and maybe such a ridiculous amount (40 ppm!) shows amber when adding the reagent for CC. I assume the spike in the TA was also caused by the added bleach. And I cannot even begin to comprehend how the FC was 0 in the morning and 40 that evening.
    Now the water looks crystalline and the spa is pristine (I had not realized how dull the spa had been until now). I am sure no living organism is in the water right now- I just hope I didn't fry the equipment!
    wjr75's Avatar
    Jun 2013
    IL
    836
    If you don't use your spa you still need to cycle the spa's floor drains (spa only mode usually), jets and blower. I have mine programed to turn the spa only on once a day for 15 minutes and have the spa jets to turn on for 5 minutes and blower for one minute. This gets fresh chlorine into all the pipes once a day.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Sep 2014
    The Woodlands, TX
    12
    wjr75, thanks so much for the advice; I will do so from now on. Clearly that is where all my problems began!
