Thread: Something strange on the steps when I came home, possibly small insects
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,258
    Today here in NJ it rained for a short period of time. I came home and the filter was not running. One of the pins loosened up. I have to purchase new pins. Although something strange was lurking by the steps. It looked like dirt in the beginning and these small items were moving by themselves. I do not know if dirt from the concrete fell into the pool and on the steps or maybe something fell off a tree or leaf, etc. Looked like small (very small insects). So I turned the filter on and decided to allow what ever was in the pool run through the filter. Came home one hour later and they were gone. (Hopefully forever). My level were tested today and everything was fine. No CC, FC was up over 3, etc. Everything was/is in check and pool water was clean.
    Any thoughts or maybe the jets in the steps were making whatever was in there move around and it looked like small insects? Has anyone ever had something this small and similar?
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Something strange on the steps when I came home, possibly small insects
    Could have just been dust of some kind...wouldn't take much to make it move.
    Catanzaro's Avatar
    Jul 2014
    2,258
    Definitely not dust. it was a lot of little moving (something). Maybe there are coming from the ground, under the concrete and dirt. There is about 3"-5" of crushed stone under concrete. If it keeps happening I will spray something in the gap which is about 1/8" max between concrete and plastic steps. There was less of them this morning and now it seems like they are gone but the filter is running. I will check again tomorrow morning.
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Could you get a pic?
    Lynzizzle
    IG, 25k gal (est.), concrete free form, Hayward S-244T 300lb sand filter,
    well water, Pump: AO Smith 3/4 hp, VSpd: Unknown, Pool Age: Unknown
    Welcome to our OOL. Notice there's no "P" in it?
    Catanzaro's Avatar
    Jul 2014
    2,258
    Wish I could but they are all gone. And believe me it was some sort of insect(s). They kind of have disappeared after the spray.
    I used a straw from a WD-40 can and placed it over this can of insect-bug spray that I had and sprayed between the cracks (did not get in the pool). Looks like it did the trick. Not really a can but a spray bottle with a tip. Weird.
    Thank you.
