Results 1 to 7 of 7
Thread: Water Flow Issue
    Water Flow Issue
    Can anyone help me trouble shoot a water flow issue with my pool. When I turn my waterfall on my salt chlorinater tells me that there is no water flow. When not running water feature there is no issue.
    ImageUploadedByTapatalk1409615085.292101.jpgImageUploadedByTapatalk1409615102.877792.jpg
    Sep 2013
    Nashville, TN
    379
    Re: Water Flow Issue
    Really hard to tell from those pictures, does the 3way valve bypass the swg for the water feature?
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Ditto
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    I can't tell from the pics but, it seems likely that that the plumbing to the water feature diverts too much water from the SWCG. If this is not normally a problem then your filters probably need to be cleaned to increase available water flow.
    It was not a problem for the first year just started acting up last month. Might be a filter issue because when I clean it it works fine for a few days and then start acting back up. How often should I be replacing my filter?
    Mar 2011
    Scottsdale, AZ
    406
    Does your water feature run at a much slower speed then the filtration/cleaning runs on?
    Filters do get slightly less efficient as they get older. Requiring a little higher speed for the same flow as you had when new.
    DFW, TX
    24,450
    I answered your filter cleaning question on your other thread. I haven't replaced my filters in 3 pool seasons I clean once in spring and once in fall. But, if algae gets away from you then you'll have to clean every few weeks until you get all the algae killed.
