Results 1 to 9 of 9
Thread: Liner coming out of coping - How to fix??
    A little different than FudgeBar's recent post...
    My liner is coming out in the corner of the deep end. Simple 16x32 with diving board and AutoPilot SWG. Pool was built in '08. What is the slick way to fix this - it seems to be getting worse and I don't want water to get behind it.
    Here's a pic... Thanks for any help!!! LOVE THIS PLACE!!!
    Mar 2013
    New Hampshire
    351
    Re: Liner coming out of coping - How to fix??
    I know it sounds simple but have you tried putting it back up there with your hands?
    18k: IG: Black Granite Liner: Aspen: 16x33.5: SWG: Polaris 280
    My pool build new-pool-build-in-nh-t60957.html
    Well...
    That's what I ended up doing. I guess I didn't search enough before posting and with a little help from the YouTube I fixed it in literally 3 minutes
    I used a light touch on a heat gun, stretched it and popped it right back into the track - was the easiest thing I did all day.
    For those out there with similar issue, Don't be afraid of this one - it is EASY!!
    Now, If I could just find an easy way to get those floor wrinkles out.....
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Does it work just as well if it hasn't popped all the way out yet? I have about a 5" section that has slipped some, but is still in the track.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    You can work some floor wrinkles out with a plunger sometimes. Very easy to do in the shallow end.
    18' x 36' saltwater inground vinyl pool
    Mar 2013
    New Hampshire
    351
    I think they used scuba gear and a vaccum to get the wrinkles out of my deep end....
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I have the same issue with my liner in 4 spots. I poured hot water on it and attempted to pull it up and back in but so far have been unsuccessful. Don't think I'm strong enough. I watched the u-tube videos and everything else. Still can't do it...
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    [QUOTE=n240sxguy;726100]Does it work just as well if it hasn't popped all the way out yet? I have about a 5" section that has slipped some, but is still in the track.
    Jeez - only did this once but having something to grab and pull up was the Schnitz - softened with heat, of course. I'm a rookie. I can't say that, if you pulled it OUT of the track so you could grab and pull up, would be a good idea. the heat gun was REALLY helpful. would have been real hard without making it pliable and soft. I guess we'll see if it's still in the groove in a week?
    I have a friend that is a pro scuba welder (crazy!) maybe I could use beer to get him to try the wrinkle job.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    I'm a PADI certified diver. I need to get some equipment so I can just go sit on the bottom of my pool. That would be absolutely awesome. May be a good birthday present next year. I could check and repair anything without even coming up for air. I'd have to see if my work would let me use the scba air compressor to air up my tanks. Here I go again. Researching things that aren't necessary.
