Results 1 to 10 of 10
Thread: Refilling 26' Above Ground
    Tink9305's Avatar
    Apr 2014
    14
    Hello )
    So we have been on this site since we put our pool but since we had already bought the "chemicals" opted to use them up before adopting the pool free method. Big Big mistake. Our CYA totally got out of control after an algae outbreak that we were unable to overcome. Since the recommended fix was a 60% water change and we also were having a sinking pole problem we decided to empty it. We are also in AZ and have a while left of swimming with our pool heater.
    So here we are with our pool almost filled and lots of bleach standing by. We just turned the pumps on. One question is what is the best way to get the CYA in the pool that we actually need? Is it ok to use a couple bags of the nasty "shock" since we already have it? Some people I have seen recommend it for that purpose only. We want to get it right this time and use this method.
    Also when should we test the water? I have the TF-100 kit and have been trying to get the hang of the different tests.
    Thanks for your input.
    And here is a picture from the initial fill )
    14,000 AG 26' round 52"deep Hayward S166T92S Pro Series 16-inch 1-Horsepower Sand Filter
    Put up April 2014 TF-100 Test kit
    Being refilled Aug 31, 2014 due to needing to move, needing a 68% water change due to CYA, and to add support under legs
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Re: Refilling 26' Above Ground
    It is better to add the stabilizer separately. In a pool your size 16 ounces of dichlor will give you FC 4.7 ppm and 4.3 ppm CYA. As you can see it would raise the FC far too high to add all the CYA at once using dichlor, and not raise CYA fast enough if you only added a bag or two a week. How many bags do you have left? Did you drain 100% of the water?
    Love TFP? Become a
    TFP Supporter!
    Aug 2014
    valrico/florida
    24
    I understand your reluctance to toss, seemingly perfectly good stuff.
    I`m so cheap I haven`t thrown any bath soap away for-well, ever.
    I wet-weld the sliver to the bar.
    Anyway, I gotta say forget the few dollars you have invested in the shock and get a pail of Cyanuric acid.
    It`s not that expensive. I`ve seen it at Wal Mart.
    When you consider the grief and work involved when it goes wrong, it`s worth doing it right-right off the bat.
    Just my opinion.
    18 ft. Round 52 in. Deep AGP 8,400 gal.
    Hayward C550-50sqft Cartridge Filter, Power Flow LX Pump 1hp. 60gpm
    Less than A Year Old
    Taylor K2005
    Tink9305's Avatar
    Apr 2014
    14
    We have 7 bags left and yes it was drained 100% since we moved it and fixed a couple poles in the back. We have a half bucket of pucks too but those are getting donated to someone that wants them on craigslist and won't be put in our pool.
    Lol about the soap we do that too.
    Sometimes I find it hard with the different names things go by.
    The bleach we got are the 3 packs of concentrated stuff from costco. The effective chlorine says 7.85
    Jun 2013
    East TN
    309
    As long as you understand what chemical adds what to your pool and how much, you fill find a time you can add a little dichlor or trichlor tabs. For instance I have 4 bags of Dichlor shock that Ive had for 3 years and I used a bag this year to raise my FC since my CYA was low. That put my CYA where I wanted it and I went back to bleach. I still have some Trichlor tabs from 3 years ago that are waiting to get used at some point, possibly a vacation.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Shirker's Avatar
    Jul 2014
    Athens, GA - USA
    132
    My pool came with a bucket of pucks and I still have a couple bags of shock. When I first opened, I added CYA but I accidentally back-washed it all out before it completely dissolved. Used most of the pucks and finally got the CYA just where I want it. Only have a handful of pucks left which I plan to keep (along with a couple bags of shock) just for CYA adjustments later (splash happens).
    TF-100 | 13.6k gal (24' Round) AG | Chlorine | Sand Filter | Two Speed Motor | Installed June 2014 | Last Opened April 24 2016
    Tink9305's Avatar
    Apr 2014
    14
    That's a good idea, I'll keep the stuff for when needed. We shall see where the levels end up.
    Aug 2014
    valrico/florida
    24
    You know, it`s really funny how easy it is to make your whole pool chemistry go haywire.
    Even Wal Mart has a whole aisle devoted to stuff that tell you how great it is and how it will make your pool sparkle.
    The local pool store is even worse and considerably more expensive.
    If it were not for sites like this everybody would be swimming in chemical cocktails and wondering which "magic" potion will get their pool water looking like it should.
    Taylor K2005
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Tink
    You might want to hang onto a few of the tablets to use should you be away (vacation, ... ) and unable to add chlorine for a few days.
    Solar Blanket, Well Water, Borax Added. 68
    Tink9305's Avatar
    Apr 2014
    14
    Thanks everyone!!
