Results 1 to 16 of 16
Thread: Drain and Refill-When to Add Chlrorine?
    Justinmc's Avatar
    Apr 2014
    Murrieta California
    14
    Hello all,
    Second time poster, continuous lurker!
    CYA was off the charts, almost fully drained and now refilling. bought the Taylor K-2006 and excited to start the TFP liquid chlorine method.
    I am sure I'll have plenty of questions but, first things first, add chlorine as the pool fills to stave off algae, or wait until it's full and then add the chlorine?
    Thanks!
    p.s I'll update my signature shortly.
    -Justin
    Newbie. OCD. 29K gal, IG, plaster, , Superflo pump, Quad 60 DE filter, Pool Vac Ultra.
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Drain and Refill-When to Add Chlrorine?
    Won't hurt to add as you go.
    Welcome!
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Sep 2013
    Connecticut
    728
    Even for the smaller Intex-type pools, all recommendations seems to be to add chlorine during the fill process. I imagine with a larger pool (more fill time, thus more time for algae to get established before fill is complete) it may be even more important to keep up with the chlorine as you go. I'm not particularly familiar with the anatomy of big in-ground pools, but I imagine you should be doing some stirring by hand if the water level isn't high enough yet to run the pump.
    Did you do your almost complete drain with an eye to ending up with an appropriate CYA level in the pool (from your remnant of old pool water)? Or do you expect to be starting from scratch, and having to add CYA to your new water?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Justinmc's Avatar
    Apr 2014
    Murrieta California
    14
    Thanks Northrn.
    Singingpond, I drained all but 1500 gallons or so, so for all intensive purposes, starting from scratch. Your logic on the larger the pool and longer the fill, the more chance of algae seems sound, I can add as I go.
    Oct 2013
    Chapin, SC
    1,141
    Off the charts is not a proper level for cya. Your cya numbers before draining would be helpful.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Justinmc's Avatar
    Apr 2014
    Murrieta California
    14
    lynzizzle's Avatar
    Jun 2014
    Sharpsville, IN
    282
    Wow beautiful pool! Have you had your tap water tested?
    Lynzizzle
    IG, 25k gal (est.), concrete free form, Hayward S-244T 300lb sand filter,
    well water, Pump: AO Smith 3/4 hp, VSpd: Unknown, Pool Age: Unknown
    Welcome to our OOL. Notice there's no "P" in it?
    Oct 2013
    Chapin, SC
    1,141
    You've either got a major leak or, that's a really old picture before you refilled it?
    Justinmc's Avatar
    Apr 2014
    Murrieta California
    14
    Quote Originally Posted by lynzizzle View Post
    Thanks! It was a repo and the backyard was neglected quite a bit by some old owners. Neighbor said he helped the guy before me pull a few chairs and child's bike out from the bottom of the pool, was so green they didn't know it was down there.
    Haven't had our tap water tested, though our county is some of the worst in the nation.
    Quote Originally Posted by timerguy View Post
    Timerguy, that was the picture as of last Saturday, it has since been filled and is a slight shade of emerald
    Justinmc's Avatar
    Apr 2014
    Murrieta California
    14
    10 AM SLAM update. Will post chem results tonight, they're at home, I'm at work.
    pool10am by JustinMc., on Flickr
    But off the top of my head:
    FC-13
    CYA-O
    Yes, zero! Did the test a few times, definitely nada. Have CYA granules in a sock in the skimmer basket while shocking the pool, does that seem ok? Didn't want to wait until the CYA was at the appropriate level to SLAM. While I realize this means more FC loss than need be, it's suppose to be 101 here this weekend, trying to get the pool ready
    Wife is dutifully testing FC for me every 2 hours and adding appropriate amount to maintain SLAM level.
    Justinmc's Avatar
    Apr 2014
    Murrieta California
    14
    3 PM picture sent by wife.
    Observation: She seems to be better at this than me.
    Almost Swim Ready. by JustinMc., on Flickr
    Oct 2013
    Chapin, SC
    1,141
    Looking good!!!! Hope you didn't add cya to get any higher than 30 to start.
    Justinmc's Avatar
    Apr 2014
    Murrieta California
    14
    Nope, added enough CYA to get to 20 while simultaneously reaching shock level at 20 CYA.
    Justinmc's Avatar
    Apr 2014
    Murrieta California
    14
    Ok so I had the idea that while the pool was mostly drained I could go to work on some of the rust stains while they were easily accessible....maybe not such a good idea. Scrubbed the spots while no water was on them, which turned the rust to a fine dust and dulled the stained spots. Yay right? Accept now the rust dust is speckled around my pool and has bonded with the plaster, and in some spots, looks terrible due to puddled water from the partial drain. From what I've read there are several possible options, chemical (concentrated absorbic acid), or rubbing vitamin c tablets. Any other suggestions? I fear my lack of foresight and thoughtfulness might have ruined the look of my pool.
    Pictures of the crime below:
    Rust problems by JustinMc., on Flickr
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    The vitamin c tablets worked very well on my vinyl liner when i opened it. Just drop a handful in the area of the stain. Probably the least expensive to try first
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    Justinmc's Avatar
    Apr 2014
    Murrieta California
    14
    Quote Originally Posted by TrevNJPool View Post
    Would you just set them on the stains and leave them until they dissolve?
    Tried rubbing a broken tablet on a few stains and didn't really work.
