Thread: Are these reasonable prices to replaster and replace tile on an old pool?
    Sep 2011
    Atlanta Ga
    310
    I just got one estimate so far. Are these prices reasonable?
    _______ Resurface Pool with White Marcite w/ Blue Quartz Plaster …………………...…............................$6,875.00
    (This is a white plaster finish with blue flakes)
    _______ Resurface Pool with Wet Edge Luna Quartz Plaster – Pacific………………...……..……................$8,375.00
    http://www.wetedgetechnologies.com/c...orites/?plid=4 – to view color and product info – customer may select any color option at no additional charge.
    _______ Replace Swimming Pool & Spa Waterline Tile – Standard 6”tile………………………………..…..$2,275.00
    _______ Replace Swimming Pool & Spa Waterline Tile – Upgraded 6”tile…………………………..……….$2,675.00
    This price includes the following:
    Second related question - How long should tile and plaster last?
    36 x 18 oval pool, inground, plaster pool.
    27000 gallons
    1 hp pump. Sand filter
    Pool built in 1971.
    38,415
    Re: Are these reasonable prices to replaster and replace tile on an old pool?
    You have a big pool ... those prices seem reasonably comparable to what we paid to have pebbleshean and tile redone.
    Of course you always want to get multiple quotes to make sure the costs are similar.
    Tile and plaster longevity are a function of how well the plaster was mixed and installed and how well you maintain the chemistry. Could be 5 years ... could be 15+ years.
    St. Louis
    12
    We just paid ~ $20,000 for a slightly larger, irregularly shaped pool. We had new tile, coping and pebblesheen installed. My research indicated that where you are located can make a significant difference in your quotes. I think that is mostly due to how many contractors work in the area. In St. Louis, there is only one pebbletec installer and we wanted that product, so the plaster job was about $13,000. We had different tile quotes that averaged about $6-8,000 from three different installers. We ended up having the plaster company do the entire job (they subbed out the tile work).
    25k gallon, IG gunite, Plaster/Pebblesheen (new in August of 2014), Sta-Rite 300lbs sand filter, TF100 Kit
    May 2013
    Monmouth County New Jersey
    19
    We just paid $17,200 for a refurb on a 35,000 gallon pool, this included tile, travertine coping and diamond brite. They demoed and redid the bond beam.
    Our previous finish lasted 20 years, but I should have probably redone the pool 5 years ago
    35,000 Gallon Gunite (circa 1990), Diamond Brite(renovation 2014), Built in SPA, 48 Sqft DE filter, 2HP Pentair single Speed, 300 BTU Heater, Solid Anchor cover, Aquabot Turbo T4RC, CircuPool Si 60+ SWG, TF-100 Test Kit
