Results 1 to 10 of 10
Thread: Cloudy Pool
    Jun 2014
    Queenstown, MD
    25
    Cloudy Pool
    Below are the readings from today:
    CYA=50
    FC=6.5
    pH=8
    TA=80
    CA=50
    The pool isn't too bad, but the water looks slightly cloudy. Any thoughts or recommendations to get the water more clear?
    Thanks.
    10000 IG plaster pool / Pentair Clean & Clear Plus 420 sqqft cartridge filter / Aqua Rite SWG T-15/ Taylor K-2006 Test Kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Cloudy Pool
    What test kit did you get these results from and has your FC ever been below 4 ? Are you using a SWG ?
    Your PH needs to be lowered. 😎
    Jeff
    Jun 2014
    Queenstown, MD
    25
    Re: Cloudy Pool
    Taylor K-2006 is the kit I use. FC has been below 4 earlier in the season when CYA was 30. I supposed it could have dropped below 4 somewhere along the line recently. No SWG. I added dry acid to achieve pH of 7.7.
    Oct 2013
    Chapin, SC
    1,141
    Re: Cloudy Pool
    When you test your water again-- like tomorrow. As soon as you've finished the fc test, immediately do the cc part as well. This may help to explain why your water is cloudy. Post the results here. Also, you should lower your pH down to 7.2 using Muriatic acid. Use pool math to determine the correct dosage.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jun 2014
    Queenstown, MD
    25
    Re: Cloudy Pool
    I took readings this evening as listed below. Note that I apply bleach in the mornings.
    FC=5.0
    CC=0.5 (or less)
    pH=7.5
    After performing the FC test, I proceeded to the CC test. After adding 5 drops of R-0003, the sample turned just slightly pink (10 mL water level). 1 drop turned it clear, so I presume CC level is less than 0.5.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,255
    Re: Cloudy Pool
    I believe if the sample turns pink you have to add R-0871 one drop at a time until clear. I have the TF-100 kit and I remember this. Maybe something is missed? Not sure, a newbie. The sample has to go completely clear.
    http://www.troublefreepool.com/threa...Kit-Directions
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Oct 2013
    Chapin, SC
    1,141
    Re: Cloudy Pool
    That's exactly correct! If I were you--and I WAS you, I'd do the test late afternoon after out of the direct sunlight. And running pump for 30 minutes. Then dose chlorine to get up to the target level. That should keep the full fc to do is job without losing any (hopefully ) to the sun.
    Catanzaro's Avatar
    Jul 2014
    2,255
    Re: Cloudy Pool
    Did vnkt0207 do the test right? Or was the step with the R-0871 drops not done correctly? Maybe there is CC in the pool causing cloudy water.
    Oct 2013
    Chapin, SC
    1,141
    Re: Cloudy Pool
    He did it how I do it, so he was exactly correct!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Cloudy Pool
    From the TFTestkits instructions:
    Chlorine Drop test - If you need to......1) measure Chlorine levels accurately or 2) higher than 5ppm or 3) test for Combined Chloramines…perform the Chlorine Drop Test. (FAS/DPD)
    1. Rinse and fill the “Chlorine only” graduated cylinder to the 10mL mark
    2. Add ONE heaping scoop of the R-870 powder and swirl to mix. (It may not all dissolve….don’t worry) The solution will turn pink. (unless you have no chlorine)
    3. Next, carefully add R-871 solution one drop at a time. Count each drop and swirl until the solution turns back to clear. Multiply the number of drops you added times .5 (14 drops X .5 = 7ppm)
    4. Record your results as FC (free chlorine)
    5. To test for Combined Chloramines, add 5 drops of R-0003 to the solution and swirl. If it remains clear, you have no CC’s. If it returns back to pink, add R-0871 as before, counting and swirling between each drop. Once the solution returns clear, multiply the added drops times .5 again…..this will be your CC reading. Record it. The total of FC and CC should be recorded as TC (total chlorine)
    Solar Blanket, Well Water, Borax Added. 68
