Results 1 to 9 of 9
Thread: Hints of Algae...do I go to a full SLAM assault?
    mkmscr's Avatar
    Mar 2013
    CT, USA
    45
    Good morning forum,
    Checked on our IG SWG pool this morning and I saw just a touch of algae on the ladder. Chems have been consistent and I will post below. The CYA dropped to 55ppm with the recent rain but I have adjusted for that over the last few days and I am sure it will be climbing as it's digested. Water is still clear, not cloudy. So my question is, should I worry about a little algae on the ladder or should I launch a full SLAM assault or is the answer in between somewhere? Thank, you folks.
    Current chem levels are in my vinyl, SWG pool...
    FC 6.6
    CC - 0
    PH - 7.8
    TA - 90
    CYA - 55, just added recommended levels to get it somewhere around 70-75ppm but it takes a few days to show I think.
    CH - is low around 70 I think but I rarely check it because of the vinyl and I read it here it doesnt have much impact on vinyl liner pools.
    17x27x37 (24000 gallons) Lagoon Vinyl liner, Hayward Eco VS Pump, Hayward 4350 DE Filter, Auto Pilot SWG, Savi LED Lighting, Maytronics Dolphin M4 Vacuum
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If you have visible algae you need to SLAM. You want to kill everything off so to do that you need to SLAM.
    It should go quickly. 😎
    Jeff
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Hints of Algae...do I go to a full SLAM assault?
    Visible algae....SLAM. It's likely to be a short one for you if you follow the process to the letter. Better to catch it now than to take the chance of the whole pool being green, right?
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    mkmscr's Avatar
    Mar 2013
    CT, USA
    45
    Thank you and I tend to agree but what if I'm already passing all the criteria in the OCLT?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Doesn't matter. Visible algae equals a SLAM.
    Get it now before it gets out of hand. It should go quick.
    It's what I would do. 😎
    Jeff
    mkmscr's Avatar
    Mar 2013
    CT, USA
    45
    I'm on it. Jugs of bleach away. Thank you.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by mkmscr View Post
    Good job ! It'll be like a mini SLAM 😎
    Jeff
    Jul 2013
    Middletown, CT
    20
    Just curious- how did you make out? I'm going to a pool party today at a friend's house who went through the same exact thing. Not sure if I should let my kids swim in the pool. Hopefully they won't be offended when I show up with my test kit.
    24' Round Above Ground w/ Vinyl Liner 14,996 Gallons
    Hayward Extreme Cartridge Filter w/1.5hp pump
    Hayward In-Line Chlorinator- Puck Fed
    Hayward Skimmer
    Taylor K2006 DPD-FAS Test Kit
    Mar 2007
    San Rafael, CA USA
    12,082
    Also, if the algae is only a little bit and always in the same spots, then consider improving the circulation in the area.
