Results 1 to 10 of 10
Thread: Slightly Cloudy Water
    When we returned from vacation, pool was being "watched" by my son-in-law, the water was slightly cloudy and the pump had died. Quickly ordered and installed a new pump and started to chlorinate to shock levels with bleach. It was somewhat difficult to get it clear so I started adding D.E. to the sand filter and backwashing every couple of hours. After a couple of days it started to get slightly cloudy once more. The pool was much more cloudy this morning, having 12 small children in the pool yesterday and a major thunder storm last night.
    PH 7.5
    FC 7.0
    CC 0.5
    CH 125
    TA 90
    Pumps runs 6-12 hours a day depending on the conditions.
    Thanks
    Jim Potter
    Hayward Power Flo LX pump and Vari-Flo sand filter. 18' X 52" agp. 8000 gals. Takoma Park, MD
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I don't see a CYA level. What is it so we can see if your FC is in range for it. How are you chlorinating your pool and what test kit are you using ?
    Most of the time cloudy water is a water chemistry problem. Low FC levels for your CYA level is one. 😎
    Jeff
    Re: Slightly Cloudy Water
    CYA is 40 and I use bleach.
    Jim Potter
    Oct 2013
    Chapin, SC
    1,141
    Maybe more important than your cya level is what test kit are you using to measure it?
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    I'm using the TF 100 purchased new this spring.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    With all the kids in the pool doing who knows what your FC may have dropped below the min.
    Keep your FC levels up and see what happens in a day or two.
    Your FC level is good now. I would always target 7 and never below 3. When you know your going to have a bunch of swimmers over its good practice to bump your FC levels up above the target slightly before and after the party. 😎
    Jeff
    Oct 2013
    Chapin, SC
    1,141
    Quote Originally Posted by takpak65 View Post
    Perfect!!!
    Just a follow-up about calcium hardness in my vinyl agp.
    The following is what the site pool calculator recommended.
    Add 175 oz by weight or 136 oz by volume of calcium chloride
    Does this sound right?
    Jim Potter
    Sep 2013
    Connecticut
    728
    Jim Potter
    Why would you want to increase calcium hardness? In the original post you report CH 125, which is fine for a vinyl pool. PoolMath suggests a range of 50 to 300, and you're right in there already.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Aug 2010
    Dallas, TX
    4,052
    If you have to backflush often, there's no need to add DE. Add the DE once everything is stabilized.
