Thread: a really tricky one:- dirty water pumped into my pool NOT after backwash or filtering
    Sep 2014
    Brisbane
    1
    Hi guys and thanks in advance for any advice on this one. i am getting dirty water pumped back into my pool for a few seconds when the pump has been off for anywhere over an hour and then comes back on. i checked other threads and everyone suggests that its about rinsing after backwashing or a damaged lateral. i have backwashed and rinsed i have pulled the filter apart (twice) and there is nothing wrong with the laterals but sure as anything each time the pump comes on i get a cloud of light brown water- and my pool is always cloudy because of this. sure i shut the pool down let it settle and vacuum to waste and for that moment everythings great... UNTIL!
    it is a 50 000 litre pool with a 2.5hp pump and a 21" filter running 100kg zeolite. i backwash according the the gauge and have a polaris 360 pool cleaner. the balance is spot on the cya salt and fc is right where it needs to be. in short my pool would be the best in the street but for this issue. does anyone have any ideas? at this point ill try anything
    cheers
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Re: a really tricky one:- dirty water pumped into my pool NOT after backwash or filte
    Welcome to TFP! Have you checked the spider gasket on the multi-port valve? The only other thing I can think of is that 2.5 hp may be too much pump for the size of your filter. Has it always done this?
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    Burlington, Ontario
    59
    Does it come out of all the returns or only one? I imagine a cracked plumbing line could do this if the ground is we out the water table is high. Are you losing any water?
    16' wide ~20,000gal IG vinyl lazy L shape pool circa 2002, 1hp Hayward Super Pump, Hayward S244T sand filter, Hayward H250ED2 gas heater, Hayward eVac Pro robot, Stenner pump for chlorine, TF-100 test kit
    2008 Gulf Coast 864 LEi hot tub
