Thread: cold region pool/spa combo
    Jul 2014
    New England - MA
    310
    Hello all, we have been contemplating an in-ground pool for quite some time and are almost ready to commit. Our desire was to have a 20x40 gunite pool with elevated spa. It would be nice to use the spa in the winter months as there are way too many freezing cold months in New England. Typically in these parts pool owners winterize and cover up both pools and spas. I feel replacing the elevated spa with a hot tub will reduce the appearance of the design, a hot tub is a bit of an eye soar. I'm curious what pool owners in cold climates have done. Is it feasible to run the elevated spa year round? I imagine that would be more costly than a stand alone hot tub. I scoured the internet all day and found very few images incorporating the two in an aesthetically pleasing manner:
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: cold region pool/spa combo
    I live in the Chicago area and close the pool end of September. We keep our hot tub open until early December. The problem is you have to run all your pumps and blower when the temp falls below freezing to keep the pipes from freezing. I would be a little nervous when the temps around here get sub zero. If somehow you can locate all your above ground plumbing and pumps in a heated enclosure it may be managable.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jun 2014
    Burlington, Ontario
    59
    If you are installing a hot tub, I think the key to maintaining a nice appearance is to sink it down nearly flush with a deck. The only trick is ensuring that the side with pumps and control pack are accessible when something breaks. Access to the internals will eventually be necessary.
    16' wide ~20,000gal IG vinyl lazy L shape pool circa 2002, 1hp Hayward Super Pump, Hayward S244T sand filter, Hayward H250ED2 gas heater, Hayward eVac Pro robot, Stenner pump for chlorine, TF-100 test kit
    2008 Gulf Coast 864 LEi hot tub
    Aug 2014
    marietta/ga
    65
    Go with a separate hot tub. You can find some nice designs for making it blend in with your pool. You will have nothing but issues leaving water in a gunite spa for the winter in your climate.
    16,000 gallons, IG
    Pebble,Sand
    Jandy 2 speed pump
    Under construnction 8-1-14
    Spa
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,777
    ^i'd second that. I'd be lost without my (separate) hot tub here in Michigan its what make winters bearable
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
