Thread: Methods to unplug an intake
    Pool Boy Hawk's Avatar
    Aug 2014
    Sykesville, MD
    7
    My in ground has two skimmers and two bottom intakes for lack of a better word. My son put a black rubber stopper in the bottom intake on the shallow end of the pool and it turned out to be a bit too small. Consequently, it was sucked into the pipe.
    Any suggestions how to get that rubber cork out?
    Hailing from the People's Republic of Maryland, the only state that taxes rain.
    27,000 gallon gun-nite in ground pool in Maryland, Nautilus NS 36 DE filter with Hayward 1.5 HP motor.
    Aug 2014
    Sykesville, MD
    7
    Exclamation Re: Mathods to Unplug an Intake?
    Quote Originally Posted by Pool Boy Hawk View Post
    Sorry it was supposed to be METHODS
    Fixed the title for you. Zea3
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Can you tell how far it went into the pipe?
    Love TFP? Become a
    TFP Supporter!
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    try putting your garden hose into the drain port inside the skimmer box and blow it back
    if you pack some rags around the hose you might be able to build up a bit of pressure
    or same idea but with pressure washer
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Jul 2014
    Peoria, IL
    389
    Re: Methods to unplug an intake
    Does the uh have any metal on it? (Like the expanding rubber plugs?). If so a magnet. If not, can you see it?
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Jun 2014
    860
    Where does the pipe end up?
    If it's at a valve at the equipment pad, you can disassemble the valve to access the PVC line the stopper is in and use a Drain King hose attachment to blow it out.
