Results 1 to 8 of 8
Thread: Pool Heating and Solar panels
    May 2014
    Central Florida
    66
    I'm just starting to look into getting solar panels for my home. If I do get solar panels should I go the route of a heat pump or solar heating for my pool? I'm sure this is a loaded question that will require a lot of research on my part, but I'm just looking for some ideas and maybe some good sites to get started. Also, please feel free to share any experiences you may have.
    16K gallon in ground plaster pool
    Hayward star clear plus c1202 Cartridge filter
    4 speed Pentair Intelliflo Pump
    TF-100 w/Speed Stir
    Manual Brush and Vacuum
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pool Heating and Solar panels
    If you've got the dollars why not both. Solar then heat pump. Where are you located? If you're not going to be using a pool cover it's like heating the house without a roof.
    Apr 2013
    Sacramento, CA
    2,769
    In Florida solar will provide you with all the heat you need from at least May to September and probably more. The rest of the year the heat pump would be the main source.
    Bob is right, a cover really really makes a difference.
    May 2014
    Central Florida
    66
    I'm in the Orlando area. I will look into a cover for the short term while I research systems.
    TF-100 w/Speed Stir
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In central Florida it is practical to manage 11-12 month pool operation with solar heat, in other parts of the country this is not practical.
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,058
    Poolstudent, we have both heat pump and solar. The solar give us enough heat from March thru October. In the cooler months we have to use the heat pump to get additional heat. We also use a pool cover which keeps the heat in the pool.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    May 2014
    Central Florida
    66
    Quote Originally Posted by Brentr View Post
    What temp do you aim for in the cooler months? My daughter is still under the age of 2 and can't keep herself as warm as us adults. Even at with the temp at 86 it takes her a few minutes to adapt to the water.
    How much of a difference does the pool cover make and what kind do you have?
    TF-100 w/Speed Stir
    Apr 2011
    Murrieta, CA
    2,360
    A lot of the studies/research has been done. Here's some great info:
    http://www.fsec.ucf.edu/en/consumer/...ools/index.htm
    The page list collector ratings, sizing and economics and a good Q&A page.
    Home the info helps.
    One of the nice things it's not from a manufacturer, it's from the University of Central Florida. The Florida Solar Energy Center (FSEC) is a research institute of the University of Central Florida.
