Results 1 to 7 of 7
Thread: How do I remove calcium in above ground pool?
    Aug 2014
    Pasadena/Texas
    2
    I have a summer escapes 12'x30". We put up aprox June 2014, 2 no ago. 1st pool. Use Walmart chlorine tabs. Used 12lb baking soda to balance all else & clear balance tabs to keep up levels. Used Walmart shock n swim, calcium! Now I have a sandy like calcium. Now I know better! How do I safely remove this sandy like calcium substance? Vacuuming with pool blaster max & maintaining levels well. Want to clear this up. We stay warmer in Texas & will be able to continue use for awhile. Already have a pro series 16' x 48" for next season. I've read chlorine bleach, vinegar, etc. chemicals are very expensive. What's your thoughts on vinegar, chlorine bleach, & baking soda to keep clear & properly balanced? Please help me clear this sandy calcium too. Over chlorinating so no probs with algae . Thank you for pointers & tips. Glad to have found a site. New to forums.
    thanks
    Amy
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,429
    Re: How do I remove calcium in above ground pool?
    Hi, welcome to TFP! Can you post a picture of the problem and a full set of test results? Usually excess calcium forms hard scale on the surfaces of the pool that feel rough like sandpaper. Not sure what you are using vinegar for, its not one of the things we recommend. Most of the answers we give are based on the test results, so we really need those numbers to help you.
    Love TFP? Become a
    TFP Supporter!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP !
    Take a look at these articles from pool school.
    ABC'S Of Pool Water Chemistry
    How To Chlorinate Your Pool
    What test kit are you using to test your water ? Here are the kits that we recommend. One of these kits will give you accurate water testing. Accurate testing is key to keeping your water chemistry in balance and in the proper ranges. The results from one of these kits will be the results we trust to give you good accurate advice on. The pool store or any other kit won't be able to do this for you. Best investment you can make for your pool. Test Kits. 😎
    Jeff
    Aug 2014
    Pasadena/Texas
    2
    I am using the strips bought at Walmart. Everything is within range from what the strip says. I think hath brand. I messed up using the shock n swim also from Walmart, which is basically made up if calcium.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    You need to do some reading, and learn a little about your water chemistry and how to test it... You need a good test kit, test strips are not accurate..... http://tftestkits.net/splash-page.html
    The above test kits are recommended.... Then slowly read through Pool School... Its a learning curve, but keep reading it will all make sense.....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    The test strips just aren't up to the task of giving you accurate test results. Do yourself a huge favor and order one the kits I suggested. If you ever have to fight an algae outbreak you'll never do it with the strips and bleach. You'll just end up dumping more junk chem's in your water.
    If you could add all your pool and equipment info to your sig that would be great ! Any questions you don't hesitate to ask. 😎
    Jeff
    Jul 2009
    Houston, Texas
    9,429
    We can teach you how to take care of your pool, but our advice is reliant on precise results that come from a high quality test kit. Test strips are highly inaccurate and do not give the precise results we need to make recommendations. The test kits we recommend are the Taylor k2006 and the TF 100 . HtH also sells a 6 way kit that may get you through the remainder of the pool season. Pool store test results are not much better than test strips on average, but it will give us a starting point if you have the water tested and post the results here.
    Love TFP? Become a
    TFP Supporter!
