Thread: Pool Math Calcite Saturation Index - Should I be worried?
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    57
    I'm always off on the Calcite Saturation Index and I don't know if I should be concerned. Here are my numbers:
    FC: 5
    CC: 0
    PH 7.6
    TA: 80
    CH 350 (our pool is 9 months old. we started at 290 and it has crept up slowly)
    CYA: 45
    When I put all of my numbers in pool match my Calcite Saturation Index, I get 0.21 and it says "Greater than 0.6 is suggestive of problems for all pools."
    All of my numbers are within accepted leveles, although I know 350 is on on high end. The area we live in has high calcium levels in the water.
    Is there something I should do?
    Thank you!
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Re: Pool Math Calcite Saturation Index - Should I be worried?
    0.21 is lower than 0.6. Anything between +0.6 and -0.6 is OK.
    You are fine.
    chiefwej
    Feb 2014
    Georgetown, Texas
    57
    Ah LOL I guess I just had a blond moment. I SAW .21 but thought 2.1.
    Thanks
    Judith and Brian D
