Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: High CYA levels
    fatboy1271's Avatar
    Aug 2013
    West Hills, CA (Los Angeles County = no water)
    128
    High CYA levels
    I'm new to this too and I'm coming from a pool service that used the chlorine pucks. My CYA is 100 and I immediately switched to liquid chlorine. Since I'm so new at this I don't know what normal additions of chlorine are supposed to be per day but right now I'm very happy spending the money to keep my FC at the recommended levels. My pool service had done an amazing job of keeping the pool crystal clear but being a weekly service just didn't have the love and care that I bring with daily service.
    Not sure if any of that helps, but that's my story
    Patrick
    Gallons = 17K / IG / Fiberglass / Filter = Hayward DE-6000 / Hayward EcoStar Variable Speed / Pentair IC40 / 1976, I believe / Shape = "Kidney Bean"
    TF-100 / SpeedStir Magnetic Stirrer / Dolphin Nautilus Pool Cleaner / Wall Whale
    Oct 2013
    Chapin, SC
    1,141
    Re: How to transition to liquid chlorine with high CYA levels
    Fatboy, Your cya measuring at 100 could be 300 or more. You need to do a diluted cya test to try to determine what your cya really is. See the extended test kit directions for how to do it. Posting a full set of test numbers would also be very helpful. You'll probably see your question and my response moved to a new thread.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by fatboy1271 View Post
    Are you sure you are only at 100? As 100 is the limit of the CYA test you have to do a diluted test unless you have already done it. While the full instructions are in the Pool School, here is the short version. Mix 50% pool water with 50% tap water. Use this mixed sample as your test water. Multiply the result by 2. If still at a 100 you will need to dilute more. Here is a great chart by JamesW to explain dilution rates and what you multiply the results by to get an approximation of your CYA level.
    Pool water......Tap or distilled water.........Multiply result by
    ....1...................1................................2
    ....1...................2................................3
    ....1...................4................................5
    Support the site
    fatboy1271's Avatar
    Aug 2013
    128
    Quote Originally Posted by tim5055 View Post
    Thanks tim5055! I appreciate you sharing the broken down equation written up by JamesW!!!
    Quote Originally Posted by timerguy View Post
    Thanks timerguy! I will do the extended test to see what I get from that. For such an important test I wish the test itself wasn't so... wonky.
    Patrick
    May 2014
    Franklin, NC
    9,184
    I agree teh CYA test troubles many folks.
    Bieng in LA with water restrictions you need to Google Pool Reverse Osmosis treatments in Los Angeles.
    Support the site
    fatboy1271's Avatar
    Aug 2013
    128
    This is probably the wrong thread for this and I apologize; however, one thing I hate about the very aloof instructions in the TF-100 kit regarding CYA testing is that they say fill to the bottom of the label and then to the top of the label. My label, probably like most, is crooked... I did read somewhere on the forums to use 14mL pool water and 14mL R-0013. Is this correct? For the extended test what kind of accuracy would I get if I did 5mL pool water + 5mL tap water + 10mL of R-0013? I use 5/10mL because those numbers are clearly marked on the testing tubes.
    Patrick
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    The normal CYA test should be performed with 1:1 ratio of pool water:R-0013 and it is the ratio which is most important.
    For the diluted CYA test with 1:1:2 of pool water:tap water:R-0013, the absolute accuracy is +/-30ppm since it is a subjective test.
    If you want to be precise, you could get the 50ppm standard solution and experiment with the lighting until you get the appropriate reading.
    fatboy1271's Avatar
    Aug 2013
    128
    Quote Originally Posted by Abigail K View Post
    Thanks Abigail; however, I'm still looking for the correct 1:1:2 ratio... is it 7mL pool water + 7mL tap water + 14mL R-0013? Can I use 5+5+10?
    Patrick
    May 2014
    Franklin, NC
    9,184
    The easiest way I found was to just take 1 cup of pool water and 1 cup of tap water and mix them in a bowl. This becomes your 1 to water solution. With the TF100 I think it is 14mL water to 14 mL R-0013.
    Support the site
    May 2014
    584
    Re: High CYA levels
    Whichever is easier for you to measure.
    7+7+14 reduces the effect of any imprecisions in the test process.
    30,419
    Re: High CYA levels
    fatboy1271,
    If you are sent a defective product and you don't notify the maker, it becomes quite difficult for the maker to send you a good one.
    In fact, I think yours was the first one this season to have that issue. They sometimes crack in transit but we don't make a habit of placing the label on crooked.
    Please send me your name, phone and address to TFTestkits@gmail.com and we'll have a new mixing tube right out to you on Monday.
    Can you explain what parts of the directions are "very aloof"? In seven years, that's a new one and some insight might be very helpful to all of us.
    As far as mixing, the test is designed to mix 50% pool water with 50% R-0013 reagent......regardless of the quantity
    fatboy1271's Avatar
    Aug 2013
    128
    Re: High CYA levels
    Thanks Dave and I didn't mean to sound insulting by using the word aloof or implying that most labels are crooked... I really do apologize because I love the site and the helpfulness of the users.
    However, as a new person to pool care it is frustrating to hear how important an accurate reading of CYA is; yet, the instructions read: "This test is the most subjective and may take a time or two to 'get' it." I truly appreciate the offer to send a replacement bottle; however, right now I'll have you save the time and money by not sending one. I will use the test tubes for measurements and see how that goes. If I really feel that I need a new bottle then I will let you know.
    Thanks everyone for the help and guidance!!!
    That makes a lot of sense to and I will use that method right now!
    Patrick
    fatboy1271's Avatar
    Aug 2013
    128
    Re: High CYA levels
    I really like the diluted test:
    14mL+14mL I was unsure of the results
    Pool + tap * x
    1part + 1part * 2 = 80 CYA
    1part + 2part * 3 = 80 CYA
    Thanks for the breakdown and I'll apologize once more if I insulted anyone in regards to the test kit and my confusion. I don't want to be looked at as someone who complains on sites. I look forward to helping out new comers as I learn more and more from the awesome users here!!!
    Patrick
    Oct 2013
    Chapin, SC
    1,141
    Re: High CYA levels
    That kinda begs the question, why didn't that show up on the non diluted test?
    fatboy1271's Avatar
    Aug 2013
    128
    Re: High CYA levels
    I've read it as 80 at times and also as 100. As part of the "it takes a time or two to get it" I think I'm understanding the lighting conditions needed to better see when the black dot disappears. I'll keep an eye on it which begs the question, should I do this more than once per week for the time being?
    Patrick
    Oct 2013
    Chapin, SC
    1,141
    Re: High CYA levels
    Without a swg you probably need to replace some water to get you to 50 ppm though. If you stay @ 80 you will need a lot more bleach to keep you at the target level for FC. It's manageable, but not ideal.
    fatboy1271's Avatar
    Aug 2013
    128
    Re: High CYA levels
    Understood; however, living in Southern California means we supposedly don't have enough water for drinking let alone refilling pools... My wife and I want to convert to SWG so we are looking into possibly doing that this winter. I've been keeping my FC in the acceptable range from the Pool School - Chlorine chart and I've had no issues with algae or at least not that I can tell. The pool is still as crystal clear as it was when I took over from the pool service and I believe I've done a good/accurate job.
    Patrick
    Jul 2014
    Peoria, IL
    389
    Re: High CYA levels
    I say no time like the present!! That or you will have to get someone to come in and run your water thru a RO (reverse osmosis) machine until it is about 40 or so.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    fatboy1271's Avatar
    Aug 2013
    128
    Re: High CYA levels
    Quote Originally Posted by bdex View Post
    Thanks bdex. It is my understanding that water restrictions are a lot me lenient in the winter. I could be wrong but it would make sense with people needing less water for their lawns and that is why we are thinking not right now. If my readings stay at 80CYA then I will maintain the needed FC range for now.
    Patrick
  20. Back To Top    #20
    Oct 2013
    Chapin, SC
    1,141
    Re: High CYA levels
    Like I said, it's manageable. Sounds like a plan.
