Results 1 to 8 of 8
Thread: Debating cover type for pool closing
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    304
    This will be my first ever pool closing. I live in an open, flat area with few wind breaks. I'm nervous about using the cover included in my pool package. The winds here have ripped doors off of two different equipment sheds in the last 3 years. I'm pretty sure (I think) that a winter pool cover wouldn't fare too well either.
    The pool place said I could remove the cover after all the leaves have dropped. There are 2 large trees nearby. Living on a farm, there will be corn fines flying around all winter as semis are loaded to go to the grain elevator. I'm considering a leaf net cover, but I'm not sure the mesh is small enough to keep out corn fines and still let the wind through. And there is the other issue of all the dust/dirt that will get into the pool without a solid cover.
    I have a partial deck and I cannot slip the cover between the deck and pool wall. I will need to connect the cover to the deck in some way.
    I recently read somewhere on the internet, I don't remember where, that a lady had damaged her swimming pool by using the solid cover in a windy area. Supposedly her top rail got ripped off the pool. Yikes! I don't want that.
    If you live in a high wind area I would really enjoy reading about how you cover your pool in the winter. I'd like to learn from your trial and error process so that I don't make too many errors
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Debating cover type for pool closing
    High wind area or lots of winter snow fall... There your best bet is a mesh safety cover. It requires instalation of anchors into pool decking, cover is held in place by straps and springs attached to anchors. They are the most costly winter covers, however. They are also called loop-loc (brand name) covers.
    Isolated Spa - 345 Gallons
    S1ngram's Avatar
    Jun 2014
    304
    I agree that would probably be the best. I have been to the loop loc website and it doesn't appear that I can use one unless I have a deck that wraps entirely around my pool. My deck is only around about 1/4 of my pool.
    Do you know of a way that I can use a loop loc cover with my current set up?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    The mesh will keep the corn fines out. The biggest mess I get from the fields is when they pick beans on a windy day. It's enough to clog my skimmer if I'm not home.
    The wind can be tough on an AG cover. Weighting it down with bleach bottles full of water usually works well.
    Nov 2011
    Moberly,MO
    1,010
    Look for hurricane above ground pool cover. We have been using them about three years now since we found them. Excellent cover for high wind no protection.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    S1ngram's Avatar
    Jun 2014
    304
    I ended up buying the hurricane cover yesterday. Other than standing up to wind, the fact that it can be cut so that it works for pools with partial decks was a huge selling point for me. Right now they are selling last year's cover which is green and also buy one get one free.
    Jun 2012
    Long Island, NY
    102
    That hurricane cover looks pretty nice.
    Thanks - John
    Pool: Sharkline Matrix 18 Round 54 Deep
    Pool Size: ~8200 Gallons
    Filter Type: Sand
    Pump: Intex 2650
    Jul 2014
    Bowling Green, KY
    45
    where did you find it??
    22X56 Intex Deluxe Easy Set Round
    14" Intex Sand filter
    Intex Saltwater pump
