Results 1 to 12 of 12
Thread: obstacle in my sand filter
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    So, I've decided to deep clean my sand filter since 1) it's never been done since I built the pool 6 years ago and 2) I seem to have a pollen problem that I'm having trouble getting rid of. So, when I opened the filter, this is what I saw...
    What is this thing and how do I remove it in order to clean the sand?
    Also, as far as I could see, it didn't look like there was much sand in there...maybe half full.
    Shouldn't there be more sand than this in there?
    TIA for your help!
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Re: obstacle in my sand filter
    Ummmmm..........I don't see any sand in there at all.
    Jul 2013
    Gilbert, Az
    116
    http://www.poolsupplyworld.com/Penta...ter/140249.htm here under resources they have the manual for your filter... It should tell you how to clean out your filter or remove that part if its removable
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Quote Originally Posted by woodyp View Post
    There is some in there, but it's only about half full. Isn't it supposed to be more full than that?
    Thanks Nuvene, but I have my manual and it says nothing about this part. And in the videos I watched on deep cleaning the filter, there was no such part shown so I'm curious what this is and why I have it. That may be the reason my sand doesn't look all that bad, but who knows?
    10,700 gal IG vinyl
    2 skimmers
    30,414
    most filters require about 2/3 sand for proper operation. Online manual would probably confirm that.
    Jul 2014
    Peoria, IL
    389
    Don't know about a pentair triton sand filter, but I have a SD60 and yes, mine is about 2/3 full and isn't that the cap that is used to center the pipe and keep sand out during filling?
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Thanks Dave. I did go read that link provided by Nuvene and it mentions lbs. of sand per product, but I have no idea how much was put in in the first place, but can certainly eyeball it for adding more.
    It also said something about a diffuser, which mine did not. I think that is what this is. That tube that I pulled out has a filter on the end of it like a faucet. I think it is an air diffuser. It did explain that it is turned counter-clockwise to undo. So that is what I will do!
    Thanks all!
    10,700 gal IG vinyl
    2 skimmers
    Jul 2013
    Gilbert, Az
    116
    So my link did help s little it looks like... I'm glad it did at least clear up a little
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    I have done the deep clean of the sand filter and added a 50 lb bag of sand. Question..is that filter akin to a toilet in that if you tighten it too much it will crack? I'm leery of doing that...done that with a toilet so I know what can happen! But, it's leaking a little from the top of the filter and I have tightened as much as I can by hand plus tapped it a little with a hammer. I'm just a little gun-shy of tightening it too much! Is that a problem? If so, any suggestions to make it stop leaking? I did wrap the top with a little plumber's tape. Should I use pool lube instead?
    TIA
    10,700 gal IG vinyl
    2 skimmers
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    anyone? Will filter crack if tightened too much?
    10,700 gal IG vinyl
    2 skimmers
    22,544
    If it's leaking where the handway/dome attaches to the vessel then you should use a little pool lube on the gasket to get it to seat easier. I wouldn't use a 48" pipe wrench on it but it can stand a pretty good amount of force.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Great! Thanks Dave!
    10,700 gal IG vinyl
    2 skimmers
