Thread: Is my IC40 dead or fuse issue?
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    While SLAMMING, I had unplugged the power on the Intelliclor IC40. When I plugged it back, there were no lights on the unit. I checked the fuse and it had blown. I replaced it with a regular (non-slow blow) 10 amp fuse since that's what was installed from the factory. These also immediately blew. I installed a slo-blow fuse, per the manual. This also blew. Any ideas? Will this be my fourth cell in 5 years?
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Is my IC40 dead or fuse issue?
    wish i could help...did you try calling Pentair? They'll probably just try to sell you a new unit but you never know.
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    Called Pentair today. Rep immediately told me the cell was defective. Somehow it was drawing too much power.
    susa's Avatar
    Oct 2010
    Deep South
    578
    Have actually replaced the fuse with a bit larger capacity fuse in the transformer, no more issues and cell is working fine.
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    It takes a 10 Amp. What did you increase it to? Slo-blow or regular? Thanks
    Jun 2014
    860
    My IC40 is wired into my IntelliTouch power panel and it is on a 12A mini-breaker.
