Thread: manual vacuum an above ground pool?
    Doughboy 16X24 AG
    Zeo Sand/Filter
    1HP pump
    Bought a Robo-Kleen that broke after 2 uses!
    Purchased a manual vacuum. Am I crazy?
    The plastic on the blue triangle manual vacuum cracked.
    My husand returned it and came home with a BlueDevil B5501C replacement.
    Anyone ever use it? Feeback?
    Vaughan Williams
    Octopus Pools
    Kyrenia
    Northern Cyprus
    Pool construction, repairs & maintenance.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: manual vacuum an above ground pool?
    Moved to Swimming Pool Equipment....
    JoshU's Avatar
    New Orleans, LA
    543
    Quote Originally Posted by mriche
    Doughboy 16X24 AG
    Zeo Sand/Filter
    1HP pump
    Using the manual vacuum is certainly a normal thing to do. Most basic pool packages come included with a manual vac.
    I still would look at getting an automatic cleaner to make things easier.
    If you need help getting it to work just let me know.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
