Thread: VS pump prices...
    Aug 2014
    Mesa AZ
    54
    VS pump prices...
    Hi - I've been tinkering with the idea of a new pump since mine seems underpowered a bit these days, e.g. I just got a Pool Cleaner and it only turns like 8 RPMs and they recommend 11. I'm going to tinker with the plumbing a bit first, but if I do buy one...
    I see a lot of people recommending 2-speed pumps over VS because of cost, but looking around I think I could get a 3HP Intelliflo VS for like $750 (after $100 rebate from the power company - it's like $853 on amazon). Compare this to what looks to be the same price almost for the 2.5HP dual speed WhisperFlo, is there any reason I wouldn't get the VS?
    One thing I do wonder is if I can control the variable speed pump via automation. With a dual speed I assume there are two sets of power terminals one for the low and one for the high speed and I can hook them up to the Intermatic for control. Can I do the same with the Intelliflo?
    30k plaster pool
    Pentair 011018 IntelliFlo, Pentair CCP520, IC40 SWG, IntelliPH Acid system
    Easytouch 4 + ScreenLogic2
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    Re: VS pump prices...
    Yes, yes you can setup 8 preset speeds then select from your preselected speeds via the automation system. I don't have automation, but I'm told it works well w the VS pumps
    BTW: You can do even better on the price. I just bought the Pentair Intelliflow VS 011018 pump for $835 no tax and free shipping. Another $29 for the couplings which are very nice, they have O-rings that seal against the pump, makes the install much easier and cleaner. You can also get a $100 pre paid Visa card as a rebate from Pentair (in addition to the power company rebate) and an extended 3 yr warranty if you have the pump professionally installed. That makes it effectively $635 for the pump delivered to your door. Mine was ordered on Thursday and received on Monday. I am very happy with my new pump!
    Bought pump here
    Rebate form here
    chiefwej
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    It said in order to get rebate must be purchased & installed by Pool Service Professional..
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I found about the Pentair Visa card rebate when I called them for advice on which pump to choose. They said any pump purchased from a retail outlet (online included) and installed by any licensed professional (electrician, pool service, plumber, etc.) qualified. As long as you have a retail receipt and a receipt for the install. My rebate has already been approved.
    The install did cost me more than the rebate, but you also qualify for an extended 3 yr. warranty with any professional install.
    chiefwej
    mas985's Avatar
    Pleasanton, CA
    11,737
    You shouldn't need a new pump to run your cleaner. Please describe in detail your plumbing setup including pump model (or picture). I am able to run my cleaner on a 1/2 HP pump.
    Mark
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Never knew a plumber could install a pump, always thought it had to be a licensed electrician, that's good to know. Thanks for the info.
    Autopilot SWG
