Thread: Success at last
    Jul 2014
    Barboursville Virginia
    6
    Success at last
    I have finally got my readings in the goals set by pool math. I am using 8% bleach. My current readings are:
    FC 5
    CC.5
    TA 100
    CYA 30
    PH 7.4
    I still get a brown/ black buildup in the center of the pool. It seems like its debris rather than algae. Doing an overnight test tonight to make sure there is no organically present. Is this normal? Property is surrounded by pine, oak, maple, evergreens and dogwoods and two crepe myrtle bushes.
    My thanks to TFPC and my new TF100 kit for putting me on the right track. My pool is crystal clear.
    17,500 gallon AG round pool, Haywood sand filter. Stopped using pucks and Chlorinator . Using liquid bleach only 8%.
    Jul 2014
    Bastrop, Louisiana
    199
    Re: Success at last
    If you have tried to vacuum it up before and it comes back, get your vac all ready and set your 7 way valve to pump to waste and vacuum it up quickly. Wait about 30 seconds to make sure its ejected out the waste port before shutting off pump and setting to normal filtration.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    Jul 2014
    6
    Re: Success at last
    Thanks I will do that tonight. Never thought of that duh!!!
