Thread: Testing to see if strike through text works
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    s̶t̶r̶i̶k̶e̶ ̶i̶t̶ ̶l̶i̶k̶̶e̶ ̶i̶t̶s̶ ̶h̶o̶t
    Direct paste from unicode generator
    Same pasted through Word Paste dialogue
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Testing to see if strike through text works
    Just use the square brackets and S
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Yeah I noticed you did it in a post one time. Good to know it's that simple.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I noticed the bracket S text markup method doesn't display as strike-through in Tapatalk, however the unicode generated strike-through does display properly in both browsers and Tapatalk.
    No biggy, but just be aware of the limitations of Tapatalk.
    Here's a link to the Unicode converter I used.
    http://adamvarga.com/strike/
