Results 1 to 17 of 17
Thread: Vacuum, Robot or In floor system
    Aug 2014
    Zapata Texas
    11
    The wife and I have been planning on where the pool is to be located and how we can keep it clean. I decided on cutting a tree that was damaged in the past which would result on less or zero leafs in pool.
    My concern would be the dust since we live in a very dry part of South Texas. What would be the best way or system to keep pool clean of dust settlement on pool floor?
    Will pool returns and skimmers help?
    Should we get an infloor system?
    I think he said 2k for the infloor system and another PB had quoted us 3k on a Pcc2000.
    We have never used a pool vacumm or robot so we have no knowledge about them.
    The pool builder is showing up tomorrow to show us layouts and an infloor system not sure what brand of system. Any ways I want to build a concrete pool about 32'x15' with basic white plaster in the next few months.
    Aug 2010
    Dallas, TX
    4,052
    Re: Vacuum, Robot or In floor system
    Welcome to TFP!
    For dust, I don't think you can beat a robot. Pool returns and skimmers help, but they aren't going to get anywhere near keeping all the dust out. There have been a few folks state they have had problems with in-floor systems, and a few love them. The thing is, one of the chores associated with having a pool is sweeping, and the robot will do that for you. And, their filter systems filter even finer than most pool filters, so they are really good at removing small stuff like dust. A robot also doesn't need additional pump HP or a second pump, it just uses good old electricity.
    X2 on the robot. In floor systems aren't cheap, and they only move stuff to the drains where they get pulled to the filter so they only clean what is easily moved. Plus, they use the pump to do it so you get dirt in the filter which eventually will need to be backflushed or cleaned. A robot uses very little energy to do an awesome job. They clean the waterline and filter (at least in my case) to 5 microns. That's clean. You just need to pop out the filter bag after a cleaning and rinse it with a hose. No lost pool water or filter canister disassembly required.
    I have friends with new pools that have in-floor systems that keep getting stuck between ports. One guy has a leaf collection vortex thing that doesn't work either. I have a Bravo Fury that I bought this year that I have been thrilled with.
    DIY 28x38x18 Full L, 26,000 gallons, Pentair VS Pump, SWG, CCP 420 Filter, Sta-Rite Max-E-Therm SR400HD Heater, EasyTouch Controller
    Aug 2014
    Zapata Texas
    11
    Thanks RobbieH
    I sure read alot about infloor systems and there pros and cons on here over these past few days. So these robots have an onboard filter or cartridge that we clean out daily or weekly.
    A Few questions on these robots.
    Do they have timers built in?
    Can I just run them at night and leave them unattended?
    Is there any certain options I should look for?
    Aug 2010
    Dallas, TX
    4,052
    They have a built in filter. I am going to go out on a limb and recommend the Dolphin Z5. The filters are very easy to clean, and it has a remote if you want to drive the thing into any trouble spots. They shut themselves off after a specific run time (differs from robot to robot). If you want one that turns itself on each day, you'll have to step up to the M5, but finding someone that carries it is much harder, maybe your pool builder can sell you one?
    I run mine unattended. I just walk out, hit the power button, and walk away. I clean it out about once a week unless it's in the fall when leaves are really heavy.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    X3 on the Robot. I thought I was going to be dealing with dust only...I bought a Dolphin Z5(cheaper and easier to find than the M5 for me). It vacuums more stuff than I could by hand vacuuming 3x. The M5 is a little better than the Z5 (third brush, and a better remote with programming options). But even with my having the lesser of the two, I can't see where any improvement in cleaning abilities would come from. I'm blown away by my Z5.
    Fast forward to this last month. Figs are in season. Birds love Figs.....I have two fig trees in my backyard....see where this is going?
    As you've guessed Birds have dropped many a fig in my pool. "Flipper" sucks those figs up no problem. I have only used the mesh filters once, that was when my PB redid the grout they screwed up the first time and dropped 1/2 of the grout in the pool. Other than that time I've run the pleated filters and flipper has done amazingly.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Aug 2010
    Dallas, TX
    4,052
    That's funny yours has a name, my friends call mine "the angry dolphin".
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Quote Originally Posted by RobbieH View Post
    Lol, We thought anything that cost that much, had to have a name.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    My kids got real creative with the name on ours. They call the AquaVac Tigershark, "Tigershark". They'll make great accountants some day...
    Isolated Spa - 345 Gallons
    Aug 2014
    Zapata Texas
    11
    The pool store told me if you don't like the pcc2000 I'll give u a free robot...uh huh. On the other hand this PB that's coming tomorrow is in the middle of an infloor and robot so really wasn't much help.
    I guess it really comes down to what robot we pick out that determines the outcome.
    If I get one it may be one of those dolphins.
    Aug 2010
    Dallas, TX
    4,052
    Well, there are robots out there that aren't much more than $200. So if they profit a grand, then give you a $200 robot, they are still ahead.
    Aug 2014
    Zapata Texas
    11
    This is a picture of how much dust accumulated in 2 days on the front entrance of our home. My parents home gets about the same even though they are across town and have grass on 3 sides of property.
    Oct 2007
    Parkland, FL
    752
    Here in Florida I've looked at lots of houses over the years, exactly one had an in floor cleaning system out of 100+ houses with pools. I'd surmise they don't work all that well.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Aug 2014
    Zapata Texas
    11
    We don't have many pools here but I do know a person who decided to get his $90k pool cut up to install this infloor system because his pool kept getting dirty. I don't know any info on his filtration system or method he was using.
    I tried uploading a picture through my phone but not sure if I did it correctly to give you guys an idea of this red or brown dust.
    Jun 2011
    Long Beach, CA
    2,790
    That is a lot of dirt and which ever cleaning system you choose it is going to be busy. I would consider an in-floor for this amount of dirt only because the robot will get a ton of work and to haul it in and out of the pool that frequently would be a chore in itself.
    I would want more of a guarantee than a robot if you are not satisfied with the in-floor system. The in-floor systems seem to work very well if they install them correctly, but are a complete waste of money if they don't get everything exact. Ask how many in-floors they have installed and if you can see any of them. Try to find some that are installed with the same shape and floor as your pool is going to be.
    Remember that the electrical cost to run a in-floor is many many times more than running a robot and you will have to brush the pool weekly with the in-floor.
    May 2011
    Los Angeles, CA
    228
    I love my WALL-E! He is the older dolphin deluxe 4 without a remote... I just turn it on a walk away. Once it is done cleaning it shuts itself off automatically. I remove the filter and set it to dry. Once dried, I shake all the dust off. The robot had worked very well even when Santa Ana winds have blown a ton of dirt into my pool.
    Suley, West Hills, CA
    IG 23000 Gallons with IG Spa Gunite plaster, Pentair Intelliflo VS 3HP, Pentair Clean & Clear Plus 420 Cartridge filter, Teledyne Laars One series 400,000 BTU Nat Gas Heater, Hayward Max Flo 1HP Single Speed Spa pump, Noisy Spa blower, Dolphin Deluxe 4 robotic vacuum.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    That is a heck of lot of dirt for a couple of days!
    This year we did major paver work around the pool as well as re-grading & landscaping. Dirt and sand all over the place. I chuck the robot in every couple of days or after a storm and it really keeps up with getting all the sand/dirt out of the pool.
    Sometimes I have taken well over a quart of sand out of the baskets. That can equal lbs of sand which the xtra weight can change it’s directional pattern, so when it starts getting jerky I stop it to clean all the sand out and give it a fresh start.
    I probably should be using the hose and Vac head for the bad days, but the robot is just too easy.
    It’s a AquaBot 4WD, it’s not fancy but at just over $600 it’s a great value
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
