Results 1 to 9 of 9
Thread: Pool test results
    Jul 2014
    Pontotoc MS
    10
    Pool test results
    Hi all I am a new pool guy, been reading a lot on this forum very helpful ordered a Taylor 2006C test kit with speed stir. I have made several test runs and feel pretty good about the results that I am getting see below. I have a Hayward T15 SWCG running @ 30 % 24 hours a day looking for suggestions on what I can improve on
    Thanks
    JC
    FC 11
    CC 0
    PH 7.6
    CYA 75
    TA 80
    CH 120
    26K IG Vinyl pool, Taylor 2006C Test kit with speedstir, Omni Logic Controller, Hayward 1HP Super Pump, Hayward T15 SWCG, Hayward S244T Pro Series Sand filter, Dolphin M4 Robotic Cleaner
    Aug 2010
    Dallas, TX
    4,052
    Re: Pool test results
    FC doesn't need to be any higher than 5-7. Any reason you are running 24/7?
    38,300
    Welcome to TFP!!!
    Well, you FC is certainly higher than it needs to be. The FC/CYA Chart shows you only need to be at 5-6ppm.
    So, first, I would suggest you stop running your pump so much and save yourself some money. With a single speed pump, you likely only need to run for 6 hours (see the Determine Pump Run Time article). Then depending on how much you change the pump run time, you will need to adjust the SWG output.
    Also, remember the pH test reads artificially high when the FC > 10ppm.
    Jul 2014
    Pontotoc MS
    10
    ok, no just started out that way and have not made the needed adjustments (fear of turning pool green)
    Aug 2010
    Dallas, TX
    4,052
    Pool won't turn green all the way down to 3ppm
    Jul 2014
    Pontotoc MS
    10
    ok I have set my pump to run 8 hours 12:00- 20:00 and adjusted the SWCG to 60% I will see if this gets me to the 5-6 ppm PS I like to save money
    Thanks for the feed back
    Aug 2010
    Dallas, TX
    4,052
    You'l probably save enough per month to buy a case of beer.
    Jul 2014
    Bastrop, Louisiana
    199
    Whooo hooo... Party at Jcaaronjr's pool... Robbie said he is bringing the beer.. LOL..
    Oppps sorry,, was having a moment there.. ok back to your regularly scheduled diagnosis.....
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    Aug 2010
    Dallas, TX
    4,052
    If I am bringing the beer, you better come to my place.
