OK, this sounds silly I know, but curiosity has bit me so throwing a hypothetical question out there. Say you need to drain your pool a bit for whatever reason, are there any advantages or disadvantages to either draining the water from the bottom vs. more from the top?
As I'm SLAM'ing and sitting outside staring at my pool enjoying the weather, I thought well the drain plug is toward the bottom, but the skimmer basket for the filter only pulls water in from the top surface, so i wonder if one is better than the other if you have to drain your pool a bit to replace some water due to whatever reason.
